Philadelphia's Classiest Drunkards
Old Sep 12, 2011 | 11:13 AM
  #27601
chu's Avatar
chu
All of my bushings are here. New Mitsubishi hardware should be here by Wednesday. Dpoing the install with Tim this weekend. Anyone have tips to offer?
Old Sep 12, 2011 | 12:09 PM
  #27602
AlwaysinBoost's Avatar
Originally Posted by grillpt
You're an animal, thats one busy a$$ schedule!
Do you plan on doing Warminster on the 25th, or are you doing another event?
no plans to autox but I'm not ruling it out. If it happens it happens...
my only advice would be to not attempt it unless you've done them before. that and be real careful when removing the vertical bolt that holds the front control arm (its the one you remove to install the Perrin PSRS). there is a nut welded into the subframe and if you're too aggressive you can and will break the nut free and have to remove the whole subframe to weld the nut back.
Old Sep 12, 2011 | 12:52 PM
  #27603
update
Originally Posted by AlwaysinBoost
ok, had a closer look at MSR and I think I know what events I'm going to do in October.
OCt 1-2 Shenandoah w/Trackdaze (evo) - registered/Instructing
OCt 7-9 Thunderbolt w/PCA Delaware (evo) - registered/Instructing
Oct 16-17 Lightning w/BMWCCA (e30)
Oct 20-21 Thunderbolt w/Schattenbaum (e30)
Oct 29-30 Thunderbolt w/NASA (evo)
all tentative until I can get approval from the wifey, but she has known for a while now that i want to end the year with a BANG and this seems like it will do the trick.
Come at me bro!
Old Sep 12, 2011 | 01:04 PM
  #27604
Tims2006MR's Avatar
Bring risque girls to said install place
I hope it goes well....not going to lie Im kinda scared
Old Sep 12, 2011 | 01:27 PM
  #27605
chu's Avatar
chu
^^^No worries TIm!
Old Sep 12, 2011 | 01:36 PM
  #27606
Tims2006MR's Avatar
so has anyone had any luck adjusting headlights? I tried on Saturday and was turning the adjustment knob that is connected to the cable and got no where.
Old Sep 12, 2011 | 01:55 PM
  #27607
dek0026's Avatar
i'm scared too and it's isn't even my car and i won't even be around the install
Old Sep 12, 2011 | 05:09 PM
  #27608
grillpt's Avatar
I did a number of years ago, it was a total pita. The little gear mitsu has in there doesn't work at all. It just spun, stripping the plastic piece it's attached to. I think I ended up using pliers on the plastic knob to turn it.
Old Sep 12, 2011 | 05:30 PM
  #27609
Tims2006MR's Avatar
Thanks I'm going to give that a try. Your rite about the pita
Old Sep 12, 2011 | 06:28 PM
  #27610
robertg's Avatar
Old Sep 12, 2011 | 06:56 PM
  #27611
igo4bmx's Avatar
Mine works fine..
Old Sep 13, 2011 | 06:33 AM
  #27612
dek0026's Avatar
This is moving too fast today
Old Sep 13, 2011 | 06:49 AM
  #27613
chu's Avatar
chu
Just looked at the calendar and realized I got off on Columbus Day, Oct. 10. I am likely to join you for the 8th/9th as a result.
Oct 7-9 Thunderbolt: Registering
Oct 20-21 Thunderbolt: Days off approved, registering.
Come at me bro!
Old Sep 13, 2011 | 06:54 AM
  #27614
honda-guy's Avatar
Looking forward to do my first drag race in like 8 years this sunday. Sucks that I can't launch the evo cause im on stock clutch. I don't want to burn out the clutch for a couple drag run when it culd last me a couple seasons of track.
Old Sep 13, 2011 | 07:02 AM
  #27615
^ ricer excuses. I launched your car half a dozen times at the PnP event
