Philadelphia's Classiest Drunkards
Old Apr 7, 2010 | 12:40 PM
  #2806
Its a 7's Avatar
Starting to look for a set of stock Evo IX wheels that aren't bent, and minimum curb rash with or without tires.
Old Apr 7, 2010 | 12:44 PM
  #2807
grillpt's Avatar
Originally Posted by dek0026
You don't think +15 is bordering on dysfunctional?
There are too many people making statements like "just put 10 or 10.5" wheels on an X". I keep reading people having issues with them. Tim runs them with a +30 offset and seems to be fine.
I'd like a little more piece of mind.
Tim's fenders are rolled correct? Why don't you talk to him and see what he say's about his set-up? He can give you feedback on any rubbing he has ie.. when, what conditions... if at all. A 9.5" wheel is plenty of width for a 265...
Old Apr 7, 2010 | 12:55 PM
  #2808
BBS's Avatar
BBS
I'm slapping 235's on a 9.5. Am i banned from the hellafunctional club?
Old Apr 7, 2010 | 12:57 PM
  #2809
chu's Avatar
chu
At least do 245 and tell people you run STU or something!
Old Apr 7, 2010 | 01:03 PM
  #2810
Jeffroevoix's Avatar
Dan you need 10.5", +15 with 275/35's
and maybe a little pull
Old Apr 7, 2010 | 01:07 PM
  #2811
PeteyTurbo@KHC's Avatar
Originally Posted by jeffroevoix
dan you need 10.5", +15 with 275/35's
+1
Old Apr 7, 2010 | 01:14 PM
  #2812
BBS's Avatar
BBS
but 245 is like...like 2 dollars more per tire! (i kid.) Guys like kittens running the +15's run 235. I'm on a +22 and plan to do a similar ride height. Figure (roughly) I'm safer by 7mm, and deduct 5mm for half of a 245 tires thats 10mm greater than a 235, then I have 2mm more fender to tire clearance than those guys (is my math kaput?) id rather have my 7mm safety zone and not have to pull my fenders (dont mind rolling.)
Old Apr 7, 2010 | 01:19 PM
  #2813
chu's Avatar
chu
Still haven't accounted for camber...which will will provide more clearance to run a wider tire! If you have tires mounted on already, bring one of the wheels this Saturday and test fit it on my car; fenders rolled and running about -1.5 degree of camber.
Old Apr 7, 2010 | 01:20 PM
  #2814
It is way to hot for early april
Old Apr 7, 2010 | 01:23 PM
  #2815
BBS's Avatar
BBS
It's not hot enough! Youre weak. Crap, didnt figure how much camber i could dial in. HMmmmmmmmmmm. Hopefully I can get the fender really rolled in on saturday.
Old Apr 7, 2010 | 01:26 PM
  #2816
BBS's Avatar
BBS
btw, with all the activity in this thread, how is there only 94 pages (with my page view settings?) Id figure atleast 10k replies.
  #2817
AlwaysinBoost's Avatar
Originally Posted by chu's brother
pictures and video will be up as soon as I find out where chu put the memory card reader.
all this fender rolling talk has gotten me back on the wheel/tire search. i need some advice.
i like rpf1's in either silver or gunmetal but there are much in the way of offset choices. the size i plan to run is 18x9.5. the only offsets made are +38 which is OEM fitment or +15 which i think would push me out of the HellaFunctional club.
do you guys think an inch wider wheel with an OEMlike offset would still look good? should i run a 10mm spacer to get a slightly more aggressive offset?
comments/opinions.......
you can run a 18x9.5 +35 (+38 w/3mm spacer) using 265/35/18's with no rubbing/fender mods at all.
edit, not sure why chu's brother's post showed up... I didn't even multi-quote.
just wanted to throw it out there dan, if you're going to spend $ on rims, go as WIDE as your budget will allow. if you can fit a 10.5" rim under there DO IT. BTW, why are you upgrading anyways... you don't even race your car you poser
Old Apr 7, 2010 | 01:28 PM
  #2818
chu's Avatar
chu
I'm sure you could run a 255 with no problems, and maybe even 265s. Bring a wheel over this Saturday!!!!
I never changed my view settings, and I see 188 pages! We are now the biggest thread in the northeast section!
Old Apr 7, 2010 | 01:31 PM
  #2819
BBS's Avatar
BBS
The te37 will make an appearance. Pull out the red carpet!
Old Apr 7, 2010 | 01:32 PM
  #2820
chu's Avatar
chu
I better bring a camera, cause that'll prolly be the first and last time some TE37s will make it onto my car!
BTW, does anyone have a mallet they can bring along this weekend?
