Philadelphia's Classiest Drunkards
Old Apr 12, 2010 | 01:21 PM
  #3121
BBS's Avatar
BBS
ots v3's are 9k/6k. Maybe ill just try and get a 10 setup in the rear. Gotta find that info for spring id and od
Old Apr 12, 2010 | 01:38 PM
  #3122
AlwaysinBoost's Avatar
I dunno much about those tires, but I'd guess from the setup I ran with Z1's those spring rates are probably close to where you want to be. That is assuming those tires don't have the level of grip Z1's do. I would just put the higher rate spring in the rear and see how you like it before swapping them out, especially if the coils were already valved with those rates in mind. what sway bar(s) are you running?
Old Apr 12, 2010 | 01:47 PM
  #3123
dek0026's Avatar
Originally Posted by steinvb12
How does the air bag thing work now?
i imagine it would work just fine. the pillar doesn't go far when they fire. i don't plan on finding out though. i really couldn't live with that perrin pod.
Old Apr 12, 2010 | 01:57 PM
  #3124
BBS's Avatar
BBS
Not so sure if I can just swap the front to the rears (though, thatd be awesome if I could.) Everyone and their mothers tout that the ots kw rates are garbage. I've never ran an event, but am planning to check out the one on the 25th at cbp. 615s are coming in as we speak for the bbs'
Old Apr 12, 2010 | 02:01 PM
  #3125
chu's Avatar
chu
You can. They typically use the same size length and I.D springs for coilovers. 9k in rear would work fine, but 6k in front is way too low imo!
Old Apr 12, 2010 | 02:10 PM
  #3126
BBS's Avatar
BBS
Im searching high and low, and nobody knows the damn length/id of the spring!
Old Apr 12, 2010 | 02:27 PM
  #3127
K1tt3n5's Avatar
Originally Posted by chu
I've seen 255 on a 10" and it's not a bad stretch either!
265s on a 10.5 are perfect all around imo.
Sandy did you get the awd d2s?
Those tires look goof on the volks man! You could do a 245/40/18 which will give you almost the same look with about a half inch more width if my tire calculator is right.
Ams and tial pulled through today! Extreme psi had what I needed in stock. My car might actually run soon.
Old Apr 12, 2010 | 02:28 PM
  #3128
K1tt3n5's Avatar
call kw? I recommend 10k front 12k rear for all around driving as well as road racing at an hpde level. Did you get a rear sway bar and bushings as well?
Old Apr 12, 2010 | 02:31 PM
  #3129
K1tt3n5's Avatar
You put better tires on your pretty wheels than your track wheels? WTF homie.
Old Apr 12, 2010 | 02:36 PM
  #3130
BBS's Avatar
BBS
Gonna call kw after work as I cant talk on the phone while im at my store. I was on the fence about 245's. A guy that actually came and picked up an exhaust from me has the same exact wheels on 245 on hotchkis springs. He said he would rub on bumps and rubs on full lock.
Old Apr 12, 2010 | 02:37 PM
  #3131
chu's Avatar
chu
Full lock is always a given, lol
Old Apr 12, 2010 | 02:40 PM
  #3132
K1tt3n5's Avatar
Just called kw for you. (I have nothing better to do) They said the id is 2.5 inches and that the length is the second number on the spring the first number is the spring rate in neutons.
Old Apr 12, 2010 | 02:41 PM
  #3133
BBS's Avatar
BBS
are you calling my volks the pretty wheels or the track wheels Volk have the mediocre rubber, bbs' will get sticky crap, and 8 enkeis will get snows/all seasons.
  #3134
K1tt3n5's Avatar
I dont rub on full lock But I don't have fender liners.
Old Apr 12, 2010 | 02:42 PM
  #3135
BBS's Avatar
BBS
LOL. Thanks for the goodluck dude! CHU! Are those hyperco springs 2.5? Need to get th edamn length when they get here.
