Philadelphia's Classiest Drunkards
Old Mar 4, 2012 | 07:25 AM
  #33526
quadrophine's Avatar
Free pizza and beer to any and all who feel like helping a brother out.
Old Mar 4, 2012 | 07:26 AM
  #33527
Evo meet at my house anybody feeling it?
Old Mar 4, 2012 | 07:28 AM
  #33528
AlwaysinBoost's Avatar
boost leaks are hard to feel and even harder to see, unless you have a pipe hanging off.
you can try switching the coils from cyl 1 and 3 and see if the cold cyllinder moves or stays.
Good luck
Old Mar 4, 2012 | 07:33 AM
  #33529
Good idea, I'm gonna get on that now.
Old Mar 4, 2012 | 07:34 AM
  #33530
I feel like an idiot that that didn't occur to me.
Old Mar 4, 2012 | 08:05 AM
  #33531
okay, switched packs up, only firing cylinder now is cylinder four. I'm sure the engine will not turn over for even 15 seconds... i cant get her to hold. i smell gasoline in the oil... i'm really worried now, the next logical step for me is compression test.
let me know if you guys have any other ideas. i have a half battery and she doesn't want to hold on for much longer i'm sure.
could it potentially be the injectors? or maybe the plugs got fouled enough that three would crap out?
I had been getting a po300 code for a while now could this be part of a problem that has been going on for some time?
Old Mar 4, 2012 | 08:07 AM
  #33532
lets hope that gas smell is just unburned fuel and not a sign of something worse.
Old Mar 4, 2012 | 09:58 AM
  #33533
so there all reading 80 to 90, with the 3rd cylinder reading 75, but with low battery. the second and third cylinder had the lowest, with the first and fourth at 90. seems a little low but i figure it's because i have a half battery. plus the engine is cold.
does this seem like there may be a problem with the 2nd and 3rd cylinders? each time they read consistently, first time i checked third i had 80 and the last time 75
the 1st and fourth consistently read 90, until i checked the first a second time i got 85 it definitely seems like i'm getting better compression in 1st and fourth consistently even with the battery falling off. is this enough difference to indicate possibly a bent piston rod caused by hydro lock? i have stock internals so I imagine if that happened it would have broke completely. I'm really pretty sure i didn't encounter enough water to lock it though. i revved up to like 6k after and then it started sputtering.
where can i find crank and cam sensors on a sunday? would advance auto or autozone or pepboys carry them?
Old Mar 4, 2012 | 10:35 AM
  #33534
Tims2006MR's Avatar
You can't just throw parts at it. These cars are not like a civic if it won't start put a distributor in it and your good these cars are complex to a point. The condition you are describing seems like a big boost leak. Just because you can not see it or feel it does not meen its not there. I blew my licp off before and its doing the same thing your car is doing. I would do a boost leak check like people have said and start ruling things out not just changing parts. How do your plugs look? After you have ruled out or fixed your boost leak then start looking in to ignition. If you do not feel comfortable there is a lot of reputable shops in the area you can take your car too
Old Mar 4, 2012 | 10:57 AM
  #33535
plugs are black, it's been rich since i got it. I have no compressor at the moment so I can't really do a boost leak test. would a boost leak cause the engine to not start at all? i can't get it to turn over anymore. I'm gonna look over again and see if i can't find something obvious.
Old Mar 4, 2012 | 11:05 AM
  #33536
just checked again, i switched number 3 plug with number 4, and now number three seems to be getting hot. i'm gonna pick up new plugs and grab my compressor.
I have an oversized oil filter... I want to change the oil as well as i'm getting a gasoline smell in my oil. does anyone have any idea what size it would be?
the mods where done by cbrd, so I imagine they recommended what oil filter to use or can i use a regular stock sized mobile 1 filter?
Old Mar 4, 2012 | 12:40 PM
  #33537
did boost leak, it will hold 25 psi, with no audible hiss it's been at 25 for about 10 minutes now with little or no falling. i'm leaning towards a cps failure, as the ignition seems to be fine.
my compression is a little low but I'm hoping that's just because the battery is nearly dead.
Old Mar 4, 2012 | 01:55 PM
  #33538
Oh My Evo X's Avatar
Hey I wanted to ask Dek, Honda-Guy, and Mr. MR and everyone else who is in the AutoX and drag community who sets up the events two questions. 1) Do you guys set up any road course tracks in the area? and 2) Not sure if this is usually a Evo only thing, but curious if you would let a GT-R in on the fun? Thanks guys!
Old Mar 4, 2012 | 03:09 PM
  #33539
Mr. MR's Avatar
HI, Most of us run with Philly Region SCCA for Autox. Your GTR bud is more than welcome as well as anyone else interested.. Here is link for Autox with Philly:
http://www.phillyscca.com/solo2/index.html
For other things going on in area you can check here:
http://www.autox4u.com/
Last thing is Motosportsreg:
https://www.motorsportreg.com/index.cfm/event/dashboard
Hope to see you out at some events. The others can chime in on the track stuff more.
Old Mar 4, 2012 | 03:50 PM
  #33540
igo4bmx's Avatar
Originally Posted by Mr. MR
For a guy with such high grammar skillz you have low reading comprehension.
I said I would want someone to layout initial purchase, then when I sold my stuff I would pay back my half. So for instance if car costs $15000, I would pay my half of $7500 a few months after purchase (once I sold my car and truck).
Why would somebody want to do this, it would address the storage and transport of said racecar..
On top of that you would get to hangout with me at events, which in itself is worth the price of admission.
Just to make sure we were on same page we could get a legal document together stating terms of car ownership between both parties, everything would be spelled out.
You still think its not a worthy idea for someone wanted to get a track car?
Why don't u spend half that monies you suggest and invest it in my car
