Philadelphia's Classiest Drunkards
Old Jun 9, 2010 | 06:44 AM
  #7066
evremonde's Avatar
Originally Posted by dek0026
performance. i do like looks too but i want to run these in autox.
er wait. do you think i should keep these are my DD/pretty wheels and run the stock wheels in autox?
decisions.
my plan was to put summer tires on the new wheel and snows on the stock wheels.
Also look into the weight of the wheel. I feel that weight is very significant for auto-x. Though maybe not as much for track use, where rigidity is paramount.
stock wheels are great for snow tires.
  #7067
CatalystGod's Avatar
so you're talking about going to a more stock offset and larger tire? will this offset ruin performance (+20. stock is +38)?
Well, In general, everything else being equal, wider tire/wheel combination gives you a less sharper turn in but usually more ultimate grip. This is what I noticed when I went from the stock setup to my current setup.
About the offset, you'll need to go to a smaller offset with increasing width anyway to keep the distance between the rim and the strut under check.
Old Jun 9, 2010 | 06:45 AM
  #7068
BBS's Avatar
BBS
Anyone know any local places that can redrill wheels? May just buy 5x120 lms and have them redrilled
  #7069
dek0026's Avatar
Originally Posted by BBS
I say dd/pretty wheels and autox wheels should be kept seperate! Dan, I think you should go advan rz over the weds. Similar design but soo much lighter (with a slightly higher price point.) I used to have weds sa70 on my suby and those 17inch bastards were MONSTER heavy.
the weds are 19lbs. that's not any heavier than the rz's or volks as far as i know.
i am not actively working on some super competitive autox setup because i still need to learn to do it well in the first place. i would however like to get something that i could turn in to a decent setup when my skills call for it.
i don't necessarily have to buy anything now. i just like looking and feeling impulsive. it's easy to hold on to $2+ grand for me.
Old Jun 9, 2010 | 06:48 AM
  #7070
chu's Avatar
chu
That is more effected my tire choice then tire width.
Old Jun 9, 2010 | 06:49 AM
  #7071
BBS's Avatar
BBS
Then they've come a very long way!
  #7072
chu's Avatar
chu
Are you crazy? You're going to make a 120 into a 114.3, only 5.7mm away from the existing hole!
Depends on wheels you get. I looked into the TC105N, and tehy are just as light, if not lighter than the RPF1...size for size
  #7073
If the tire brand/type is kept the same and width is increased, does it not behave in the said manner?
Old Jun 9, 2010 | 06:52 AM
  #7074
BBS's Avatar
BBS
This chat is way too car related this morning. Aint feeling this
Old Jun 9, 2010 | 06:53 AM
  #7075
chu's Avatar
chu
I meant to say tire choice then wheel width, not tire width, sorry.
Old Jun 9, 2010 | 06:54 AM
  #7076
AlwaysinBoost's Avatar
I wouldn't worry as much about wheel weight as I would about width. go WIDE! you want the largest contact patch possible, weight is secondary to width.
Old Jun 9, 2010 | 06:55 AM
  #7077
aah, makes sense.
Old Jun 9, 2010 | 06:57 AM
  #7078
BBS's Avatar
BBS
A mantra I use to discern which females im going to bone
Old Jun 9, 2010 | 06:59 AM
  #7079
IMO the order of importance goes like this
widest wheel you can fit
widest tire you can fit on that wheel that give you the best overall gearing
lightest wheel you can afford
how the wheel looks
  #7080
chu's Avatar
chu
I ordered a set of hubcentric 20mm slip-on spacers earlier this week, but I dont think I need them anymore...
