Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
The Next build.
Old Nov 25, 2006 | 10:57 AM
  #31
06evofiji's Avatar
That looks kick a$$ man I like the black...keep us updated
Old Nov 25, 2006 | 05:48 PM
  #32
LimPShoT's Avatar
Build Day 6
Ok got manifold/turbo/DP all bolted up. Oil return line was a pain in the $#Q$#@ to fit right if that thing leaks i am going postal. waste gate dump tube is a tight fit with the DP/lower ic pipe right there i might have to reposition to get it just right.
Attached Thumbnails The Next build.-dscn0378.jpg   The Next build.-dscn0379.jpg   The Next build.-dscn0381.jpg   The Next build.-dscn0382.jpg
Old Nov 25, 2006 | 07:44 PM
  #33
Paul Nelson's Avatar
Come forth my son
Old Nov 25, 2006 | 07:50 PM
  #34
LimPShoT's Avatar
tell me paul which way do you have the Waste gate dump pipe pointed toward?? yours look something like this??
Old Nov 25, 2006 | 08:45 PM
  #35
That is correct my son but however put a clamp on that licp...
Old Nov 25, 2006 | 08:46 PM
  #36
Might have to extend the dump tube cause it will blow on the starter wires
Old Nov 25, 2006 | 08:58 PM
  #37
LimPShoT's Avatar
Yeah i know that is just for mockup, and quit calling me your Son I am older than you remember!! I will try to get the wg pipe repostioned a little better off of the starter.
Old Nov 26, 2006 | 05:53 PM
  #38
LimPShoT's Avatar
Build update day 7
Well had to pull everything out and get the manifold seated better on the block a slight setback but got the coolant/and oil lines ran lower IC pipe is clamped up its a tight fit between IC/wg dump pipe/ DP there real close together should be ok with heat since they are ceramic coated. Need to have new upper radiator hardline made, and will be back at it on wednesday.
Old Nov 26, 2006 | 10:00 PM
  #39
EVO Tweeker's Avatar
Let the fun begin....
Old Nov 29, 2006 | 09:36 PM
  #40
LimPShoT's Avatar
Build update day 7
Today got new upper radiator pipe/intake/upperpipes/Wideband in bung all installed. Now just need to wire egt/boost/wb/zeitronix setup and run the rest of the exhaust throw some colant in it and get MR tuner over here and we can start it up, and see if i got an leaks or other issues that need to be resolved.
Attached Thumbnails The Next build.-dscn0395.jpg   The Next build.-dscn0396.jpg
Old Nov 29, 2006 | 09:40 PM
  #41
Jim_Patterson's Avatar
Whos gonna tune it and with what?
Old Nov 29, 2006 | 09:58 PM
  #42
HPF Kyle's Avatar
Im tuning it...with the aem he's going to buy from me... right Eric
Old Nov 29, 2006 | 10:07 PM
  #43
LimPShoT's Avatar
lol yeah right!! Tuning with ecuflash, logging with evoscan and zeitronix. Tuning will be performed by a tuner which has mass quantities of superior brain waves in direct correlation to Car/Mind/Laptop.
Old Nov 29, 2006 | 10:11 PM
  #44
HPF Kyle's Avatar
Tuning not Tunning my son.
Old Nov 29, 2006 | 10:28 PM
  #45
LimPShoT's Avatar
thanks for the spell check. And your to short for me to be your son and to young!!
