newbie need help!!!!!!
I need help with tire information,I drive a lancer evo IX 2006 and the inside part of my tire(+/- 4cm) the tread is all gone.(all 4 of tire).the vehicle have 10000ml on it.everytime i take corner at 45mph,i loss the enhancing grip.
And how to adjust the greddy BOV type rs.(it set more toward to the soft or more to hard section) Any information will be helpfull. Thank you
The stock Advan tires are only lasting between like 8k & 15k miles. They will last longer if you regularly have them rotated and flipped.
As far as adjusting the BOV if you do not know how then I would find someone near you, maybe a good shop that can do it for you. You don't want to do it yourself and set it too stiff so that you get compressor surge. You also don't want it too soft and just have it leak.
Wow...sounds like your camber is way off if the inside of your tires are all chewed up?
You drop your car at all? Taken it for an alignment?
If you look at your car front on, do the wheels look like this |----| or like this /----\
If its the second one, your camber is off.
I believe you were meant to say cambers, not toe. Toe should be zero all around, if you want your tires to last longer.
nicekyo
22
Feb 8, 2011 03:56 PM
Shima211
Sep 11, 2009 10:42 PM
Tnnrx7
24
May 30, 2008 02:45 PM
