Outlander Sport (RVR/ASX) : Wheel Alignment
From: Out towards the countryside of Dallas, TX (USA)
I bought my 15 new and it pulled bad left from day one. At 1900 miles I took off work to make my appointment for a check at the dealer. They drove it and said it was fine. I left the lot and drove straight to an alignment shop and paid 75$ to have it fixed. Attached is the alignment before they fixed it.
Your:
Front Right toe is quite a bit off! at .21°
It should be .03° (with a deviance +/- of .12°)
Left Rear toe is WAY off too, at .32°.
Same as above.
I'm guessing not only are you experiencing that pull but also poor MPGs...
And, eventually you're going to get premature tire wear too if you leave them as it is. > Keep an eye on your tire treads, especially those that have the excessive toe.
Your dealership should have tested your alignment on the machine and Not just drive it around.
The tolerances of these AWD vehicles are too stringent to try to figure out by "eye-balling it" or by feel.
I'd suggest you make note of which tires they were and have them rotated to the back axle so to mediate further premature wear.
Bringing this back from the dead...we are looking at ordering a 40mm spacer lift kit soon. It does state that an alignment will be needed..Is there enough adjustment on the stock setup to adjust what is needed? Or should I look into replacing the arms with the adjustable MOOG ones for camber? Thanks
mRVRsport
Outlander Sport
10
Jul 19, 2025 09:35 AM
deeman101
Mar 3, 2021 07:56 AM
mRVRsport
Outlander Sport
18
Oct 10, 2018 02:05 PM
mRVRsport
Outlander Sport
26
Nov 2, 2017 09:53 AM
mRVRsport
Outlander Sport
67
May 5, 2017 04:56 AM
