$100++++ for routine maintenance?!!?
Old Jan 14, 2014 | 09:47 AM
  #31
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
Originally Posted by Wesley Eng
Used the first free oil change coupon from Mitsubishi today and here's what else I found out.
-Tire Rotations are $29 so I declined
-If I bring my own oil they will charge me $15-$20 for labor
-NO OPTION TO AUTO-LOCK WHEN SHIFT TO DRIVE!!
-My Airbag light is due to my aftermarket NAV install shorting out the airbag light on the center console or something like that
Oil was changed at 5,900 miles/6-7 months since purchase
Not sure what you mean..
Really? Well, that's good to catch that problem BEFORE an accident occurs. Hope you get that grounding issue fixed asap.
Old Jan 14, 2014 | 11:25 AM
  #32
RA012124's Avatar
The mechanic told me as long as the airbag light on the DASH comes on during the systems check when you first turn your key to ON, then the airbags will deploy. In my case, it has to do with something about the passenger light on the center console, like the bulb got shorted or something which is why the airbag light is on.
I asked them to program my doors to lock when shift to drive if possible and the mechanic checked, but there's no option in our vehicles for that feature.
Old Jan 14, 2014 | 12:09 PM
  #33
mRVRsport's Avatar
I see.
Thank for clarifying.
That's too bad.
It would be a good safety feature to have.
Old Jan 14, 2014 | 01:23 PM
  #34
Burtonrider1002's Avatar
EvoM Moderator
I don't believe that's accurate. I KNOW it is a changeable option in the ETACS ECU for the 2011 models, and I highly doubt would change it because other countries require it. It would be silly to manufacture two ECU's, one for the US, and one for the Global ASX/RVR.
Old Jan 14, 2014 | 02:04 PM
  #35
EvoM Moderator
Just got these in an email from
Feel free to print/use them
Old Jan 15, 2014 | 01:24 AM
  #36
RA012124's Avatar
I need to hit 7,500 miles before 3/21/2014!!!
MercuryMR
May 11, 2016 06:28 PM
DjRags604
Aug 19, 2014 05:40 AM
chrispyology
Oct 30, 2012 06:21 PM
jrsimon27
Apr 25, 2010 07:22 PM
kts262
Jul 10, 2008 06:32 PM
