Wipers- disable rain sensor and have intermittent only?
Old Sep 23, 2016 | 07:43 PM
Dustball's Avatar
The auto rain sensing wiper function basically sucks. Is there a way to disable the auto rain sensing function to basically turn the sensitivity adjustment selector into a manual intermittent selector?
Old Sep 26, 2016 | 11:08 AM
AWCAWD's Avatar
Yes, it is possible but it requires to program your ETACS. Search for keywords as "ETACS Decoder" or "Diagbox" .
Old Sep 26, 2016 | 08:08 PM
Dustball's Avatar
So it's a programming change and not as simple as unplugging the rain sensor?
Old Sep 27, 2016 | 11:12 AM
AWCAWD's Avatar
I do not have this option in my car but isn't it even a simpler solution to turn the switch to "off" position? Whenever you need it you may turn it back on and select the appropriate speed. Simply do not use the "auto" setting.
I am not sure but I suspect if you unplug the rain sensor you might get an error message on the center display. Try it and see.
Old Sep 27, 2016 | 09:06 PM
Dustball's Avatar
It is on the OFF position most of the time. The problem I'm having is when I need something in between OFF and LO- a true intermittent. When it's in Auto mode and the rain varies in intensity- sometimes the wiper will slowly increase in frequency and speed until it's running nonstop, even when the rain has let up to nearly nothing.
Old Sep 28, 2016 | 05:08 AM
Landshark's Avatar
sounds like something is screwed up - see if you can recreate that behavior with a hose, then take it to the dealer and try to demonstrate to them.
Rain-sensing works pretty good in my wife's OS - kinda wish i had it in my car.
Old Sep 28, 2016 | 12:34 PM
Nast_Nas's Avatar
you do know you can change the "auto" speed/sensitivity with the switch right, by acutall turning it up/down
Old Sep 28, 2016 | 12:39 PM
Nast_Nas's Avatar
here
Attached Thumbnails Wipers- disable rain sensor and have intermittent only?-2016-09-28_14-38-46.jpg
Old Sep 28, 2016 | 09:01 PM
Dustball's Avatar
Yes, I am fully aware of how it works.
EricJ@AMS
Feb 12, 2010 03:01 AM
aleclance
Evo X How Tos / Installations
Jan 22, 2010 02:49 PM
EricJ@AMS
Jan 17, 2010 11:26 PM
marylandevo8
Dec 14, 2009 04:54 PM
GolfTango
20
Apr 18, 2007 04:41 PM
