MAP Stage 2 LR 2.4L Build
Old Aug 23, 2012 | 06:49 AM
  #511
Adam Brunson's Avatar
Originally Posted by jmcmill3
Collin,
Do you have experience with this setup on a stock return line? Meaning if it would clear?
That's the feed line, and it clears factory just fine.
Old Aug 23, 2012 | 12:51 PM
  #512
Blue91lx's Avatar
Originally Posted by Adam Brunson
Take off the fitting and put a 30 degree on it, at most a 45. Put the fitting on facing 7-7:30 and it will still look clean and work just fine. Throttle body includes bolts to go through about 10-14mm of flange, why did you need different bolts in the first place? Let me guess the flange isn't threaded......
The flange isn't threaded, but it was no big. Curt's going to be including bolts with all of the IMs now and offered to reimburse me for the bolts without me saying anything .
You think a 45 would clear? I'm worried about buying fittings and having them not clear seeing as the damn things are like $20 a piece. I already have $50 in fittings that didn't fit other stuff, but no -8an. We will find out soon.
Old Aug 23, 2012 | 01:20 PM
  #513
ToxicFab's Avatar
A 45 should be perfect. That's what I'm using on mine and it clears fine. No way a straight would work on mine.
Collin
Old Aug 24, 2012 | 06:24 AM
  #514
I think a 30 would be better and pointed at 7:30 it will look more "straight/natural" in my opinion. 45 will work too.
-8 huh? Overkill.
Old Aug 24, 2012 | 07:12 AM
  #515
Blue91lx's Avatar
Oh, I know the -8an is overkill. The previous owner had an inline pump right there with -8an line on both sides so I just put a -8an hardline and never felt the need to change it.
Is this the BAT you're speaking of?
http://www.batinc.net/mocal-central.htm
I want to get a -45* just so I know it will clear. Also....$35 a fitting is a bit nuts haha. I use JNZ's fitting guy and he can get me a -8an 45* swivel for like $15 and I've never had one leak or break. That's what I used on the entire catch can and fuel rail setup that I have now. Do you not like his fittings?
Old Aug 24, 2012 | 07:30 AM
  #516
A. Where do you see 35.00 a fitting
B. I don't know what your talking about, I don't like who's fittings?
Forget I said anything, buy a 30 or 45 and it will work. Continue on......
Old Aug 24, 2012 | 08:24 AM
  #517
Blue91lx's Avatar
A) No need to be a doucher, I was working in the garage and scrolled too far down to the wrong prices. They're actually really cheap. Thanks for showing me them.
B) The fittings that JNZ sells. Not sure of the brand.
Word.
Old Aug 24, 2012 | 10:06 AM
  #518
JNZ's fittings are just fine.
Old Aug 28, 2012 | 02:03 PM
  #519
dizaryl's Avatar
Hey, thanks for all the pictures. Except the one of your brother, he's hamosexual right? Next time your in IN bring some Yeungling and leave the Saturn in PA. Your out of town fancy Saturns are cutting in on my Fiero sales. Peice!
Old Aug 28, 2012 | 02:31 PM
  #520
Blue91lx's Avatar
Yo Driz, Saturn's cooler than the Evo but my fridge is filled with lager at the moment.
Where you is in IN?
Old Aug 28, 2012 | 05:18 PM
  #521
dizaryl's Avatar
The one and only Indianapolis. Indiana means Indiana, apolis means city of in Latin... I think. Going to Fathouse tomorrow to see if they can make my ride any sweeter than it is. I have an aftermarket PINK car seat in the back(NFS) and a impact removed front air dam much like the one your evo originally sported me thinks. You went with the Duraflex bumper cover? Anyway I have an empty Yeungling Laaaahhhhggger can that I refill with Stroh's to sate my thirst. And refill it I shall. piece "my friend" (sorry couldn't resist Levar)
Old Aug 28, 2012 | 06:01 PM
  #522
Levar's Avatar
Veteran: Army
I see that my good manners are paying off, my friend.
Old Aug 28, 2012 | 07:22 PM
  #523
Blue91lx's Avatar
I heard those seats are good for quite a few HP.
Due to your Midwest heritage I'm truly surprised your beer of taste isn't 'Boxer'.
Everyone is picking up on your manners lately .
Also, folks, I have a hard decision to make.
I must decide between buying a Vband, small tube, T3 kit from Fathouse (to run a BB 6262 come winter) or a Buschur Cast 37r kit that's for sale in the classifieds. I want to do a turbo now and be done with the car instead of having stuff over my head that I know I can change in the future.
Official goal is 550-600whp on 93 and full boost before 4500.
Old Aug 28, 2012 | 07:27 PM
  #524
Levar's Avatar
Veteran: Army
The 6262 is smaller than the 37r, right? If I am not mistaken, the Buschur cast manifold will assist in spool as compared to the T3 manifold, right? That said, both turbo options are great but the 6262 is more popular these days.
Old Aug 28, 2012 | 07:43 PM
  #525
Blue91lx's Avatar
Yes, the 6262 is a little smaller than the 37r, but I wouldn't be spinning the 37r fast enough for it to reach it's efficiency range.
The Fathouse kit would be a small tube design, which is probably just as conducive to spool up as a Buschur Cast manifold.
