Boltz.' Evo Build 2012. The Final Chapter.
Old Oct 3, 2012 | 09:50 AM
  #76
Boltz.'s Avatar
FCOTM Winner
Originally Posted by wizzo 8
Looks like some good driving there Justin. Im going to have to try an e-brake launch next time I go out to the track. Did you use the e-brake when we went to track?
Thanks Jerry. That's nothing compared to what I know can be done with the QM clutch..... I'll make sure to make a comparo vid when I get the QM
I didn't use the ebrake then, but it does remove all the slack in the drivetrain... The only issue is the outer intermediate plate on the exedy (PP02) will be taking a lot of heat when you do the ebrake preload method. That sucker warps easy too.
Originally Posted by CBRD
That is a very pretty turbo kit you have there
hee he!
im sure everyone that has been picked them up lately will enjoy them-
here is a link to the kit!
http://cbrd.mybigcommerce.com/cbrd-l...bocharger-kit/
cb
Going to do some comparo graph's today from the dyno.... I'm excited to see how it looks!
Originally Posted by R/TErnie
QM twin!
Yup! Turns out that there is no difference in friction material between street and race clutches, so QM 8leg street here I come!
Originally Posted by Evosick2332
I rebuild my Clutch 2 times a season. Once at the beginning of the season and once right before the Shootout.
Thanks Joey. Good to know.
Old Oct 3, 2012 | 12:49 PM
  #77
Boltz.'s Avatar
FCOTM Winner
Custom Airbox/shield I made. Work in progress still but allows some ducting to be routed in and completely blocks the radiator and header from the intake.
Old Oct 3, 2012 | 05:26 PM
  #78
wizzo 8's Avatar
Not bad. Where do the ducts go?
Old Oct 3, 2012 | 09:11 PM
  #79
Boltz.'s Avatar
FCOTM Winner
Made a blockoff plate (that sits behind the vent for oem look) for the drivers side with two air ducts on it. Was a pain in the *** to get by the ACD pump.
Old Oct 3, 2012 | 10:02 PM
  #80
evosam726's Avatar
Looking good bro, keep it up
Old Oct 4, 2012 | 09:09 AM
  #81
Boltz.'s Avatar
FCOTM Winner
COMPLETE CBRD LMP TURBO KIT REVIEW
Old Oct 4, 2012 | 09:26 AM
  #82
Boltz.'s Avatar
FCOTM Winner
Old Oct 4, 2012 | 01:28 PM
  #83
tscompusa's Avatar
get rid of your emission stuff on the intake manifold.. it will clean it up a lot more. good times at the strip.. i am interested to see how much ET you drop with the QM. its a really good priced clutch that performs amazing.
Old Oct 4, 2012 | 01:35 PM
  #84
B.J.@ToxicFab's Avatar
Your intake heat shield/air ducts look good, simple & I'm sure it works well. I will be doing something similar on my car swap I swap in the non-acd t-case & remove all the acd junk...
Old Oct 4, 2012 | 03:05 PM
  #85
wshihdnevo's Avatar
This car is a beast & so hawt!!! Love the innovation on the body work! Looks so mean!!!
Old Oct 4, 2012 | 04:09 PM
  #86
rhd-jon's Avatar
nice nice
  #87
wizzo 8's Avatar
Originally Posted by Boltz.
I have the same setup except I only have one on the far right corner. I think it works but yes its a pain in the --- to get around the ACD. Nice and hidden.
Old Oct 5, 2012 | 07:47 AM
  #88
jmcmill3's Avatar
whats that red thing where the battery goes? is that some kinda junction block? if so where do i get it....!!!!?
Old Oct 5, 2012 | 08:44 AM
  #89
Boltz.'s Avatar
FCOTM Winner
I don't know exactly what they would call the part, but its a modified underhood positive battery terminal from a BMW (BMW also does batteries in trunk). When you move the battery to the trunk you still have wires to hook up in the engine bay (obviously). I wanted to have this terminal mounted somewhere and available to tap into instead of just hooking up the wire to the battery to the stock terminal, taping it and hiding it.
Old Oct 6, 2012 | 02:57 AM
  #90
evilempire76's Avatar
Where did you get the hose you used for the intake ducting?
I did something similar, but I used shop vac hose. I plan on making an air box as well at some point.
Your car looks really good! I know it can be a pain in the *** to work with the reflecto gold in regards to getting it to stick to certain items.
