Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Feb 26, 2013 | 06:12 PM
  #211
Wheatley's Avatar
Metal glaze is easy to sand if you're wanting a very thin coat filler to use. Any degreaser should work well, I tend to not dilute mine much and use a soft or medium bristle brush to break the grime away. Don't forget to plug your holes if power washing.
Old Feb 26, 2013 | 06:39 PM
  #212
EvoDan2004's Avatar
ok great. yea i plan to put some on my finger and wipe over the tiny dimples if that is possible. nothing crazy. yes i will be plugging all the holes before i wash and while i paint. thanks ill grab grease lightening and get to work.
my tie rod ends are at the post office. ill grab them tomorrow. maybe i can power wash this thing this weekend.
Old Feb 26, 2013 | 06:55 PM
  #213
antilag_200's Avatar
get rid of those power steering lines while you are at it , replace with kevlar/Pro AN lines, saves a little weight
Old Feb 26, 2013 | 07:00 PM
  #214
EvoDan2004's Avatar
i thought about that for about 2 seconds. i have not really thought about it much more. i honestly do not even know where to start with that type of mod. i would be interested in it for sure. i believe i saw ToxicFab do something like that. but i thought it was for show.
Old Feb 26, 2013 | 07:06 PM
  #215
mullen's Avatar
Go with an mr2 electric power steering unit!
Old Feb 26, 2013 | 07:10 PM
  #216
EvoDan2004's Avatar
if there was a kit i could buy i might do that. but we all know evodan cant wire up a damn boost gauge. i hate wiring. i know David was thinking of doing one but i do not think it ever came around.
Old Feb 26, 2013 | 07:24 PM
  #217
mullen's Avatar
I have all of the required part numbers and such but it's on my other laptop (broken screen)
Old Feb 26, 2013 | 07:30 PM
  #218
EvoDan2004's Avatar
i sent david a message LOL. maybe we can get something going for this. do you recall if it would drop weight?
Old Feb 26, 2013 | 07:55 PM
  #219
mullen's Avatar
I doubt it'll shave weight but it will definitely free up power.
Old Feb 26, 2013 | 08:44 PM
  #220
R/TErnie's Avatar
Mount the mr2 pump in the trunk... Better weight distribution
Old Feb 26, 2013 | 09:22 PM
  #221
LGshow19's Avatar
Dan do the mr2 pump!
Old Feb 26, 2013 | 09:26 PM
  #222
nollij's Avatar
Mind posting it in this thread for the world? A PM will suffice too.
Old Feb 27, 2013 | 04:24 AM
  #223
EvoDan2004's Avatar
We will see what happens. It needs to be pretty basic and work with my stock ecu/F-Con. I will prob mount the pump right on the fire wall under the intake manifold.
Old Feb 27, 2013 | 04:37 AM
  #224
The main pressure feed line ( the big rubber one coming from pump) isn't the lightest thing out there and can be replaed with -6 AN line ( power steering specific hose has to be used).. the return line from the rack, can be regular pro lite hose, or you can bend your own out of aluminum , just like the stock set up..
What year mr2 does the electric power steering come in ? Reason I ask is that i have a customers 91 turbo mr2 in for work at the moment and check rather easily.
Old Feb 27, 2013 | 08:48 AM
  #225
mullen's Avatar
It's been 6 months or so since I actively collected data but let me see if I can copy all of my data from the other laptop to my mac. I have everything from mr2 part numbers to install tutorials, other pumps with reservoirs on the pump itself for a clean setup, and even pigtails to make the install easier. I honestly may use the one with the reservoir built in and mount it under the intake manifold with an electric water pump.
