Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Feb 22, 2013 | 06:45 PM
  #181
EvoDan2004's Avatar
Originally Posted by Wheatley
I pull it as a whole, separating is way to much work lol. A leveler helps imo
trans and engine out the top? i didnt think it was possible without scratching stuff. i do not have the height to drop everything out the bottom.
Old Feb 22, 2013 | 07:17 PM
  #182
LGshow19's Avatar
Originally Posted by evodan2004
oooooooo yea i didnt think of that. OK now i just need chain. LOL
Yeah a washer lol
And what wheatley said... as a whole, but hey like people say "there's more than one way to skin a cat"
Old Feb 23, 2013 | 06:54 AM
  #183
tsidrift1's Avatar
I was expecting to see more pics by now! haha
I always drop the trans from the bottom, then pull the motor out of the top. Always did it that way on my 1g, so I did it that way on the evo. I will say, the 1g was A LOT easier than the evo was to do it this way.
Old Feb 23, 2013 | 07:31 AM
  #184
Wheatley's Avatar
with a leveler it makes it possible, It allows you to put it at an angle and pull it. Ive done top, bottom, in pieces etc. I prefer top all one piece with a leveler the best. I tape everything every time I work on the car anyways just in case.
Old Feb 23, 2013 | 08:04 AM
  #185
EvoDan2004's Avatar
i did the same thing. trans out the bottom and engine is coming out the top.
i should have the engine out today so i will snap some pics.
maybe i will put it back in this way
Old Feb 23, 2013 | 09:01 AM
  #186
4g63evoeight's Avatar
Do you have the transfer case still in the car pulling everything out from the top or do you remove that first
Old Feb 23, 2013 | 10:21 AM
  #187
Wheatley's Avatar
I've done both. Sometimes I strap it away from the trans sometimes I pull it. The only thing I always remove is the radiator and turbo/manifold. Allows it to be pulled forward away from the firewall. Last time I put the engine in it was done and ready to fire in an hour and a half but my car is simpler than a stock car.
Old Feb 23, 2013 | 10:49 AM
  #188
badev0's Avatar
I remember my first trans pull, LOL. Kidding.
Dan's account is disabled?
Old Feb 23, 2013 | 02:44 PM
  #189
batty200's Avatar
I drop the whole thing out the bottom all at once. Seperating the trans first is a PITA. I would rather pull the whole thing out the bottom then just pull the trans alone. I guess a lot depends on whether you are working on a lift or not. I like pulling the front bumper and IC and radiator so I have lots of room. I am going to pull the motor out of my car hopefully in two weeks. I was going to do it today but the trailer brakes broke. Last time I did it I had two motors out and in two cars in two days with a trans rebuild in between.
Old Feb 24, 2013 | 11:33 AM
  #190
EvoDan2004's Avatar
i am back.
anyways the engine is out. i am having trouble removing the front sway bar. any pointers? i was hoping i do not have to lower the K member
Old Feb 24, 2013 | 11:49 AM
  #191
badev0's Avatar
You have to lower it unless you cut the bar out. But unless you are installing a new one, has to be lowered eventually to get the new one in...
Old Feb 24, 2013 | 11:53 AM
  #192
EvoDan2004's Avatar
damn ok. i am going to be putting one back in. when you say lower am i just loosening to bolts or actually dropping it
Old Feb 24, 2013 | 11:56 AM
  #193
EvoDan2004's Avatar
here is a pic with no engine.
Old Feb 24, 2013 | 04:28 PM
  #194
EvoDan2004's Avatar
Dash is out and I removed the shifter cables, throttle cable, some aftermarket wiring. Next is the heater core and brake booster.
Old Feb 24, 2013 | 04:35 PM
  #195
asmo's Avatar
Nice, looks like its really coming along.
