Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Feb 5, 2013 | 06:52 AM
  #76
badev0's Avatar
Yeah I agree. They make real nice turbos also....
Old Feb 5, 2013 | 06:54 AM
  #77
StreetThisEvo's Avatar
Originally Posted by evodan2004
i have decided to pull the engine out of the car and repaint the engine bay. i already will have the turbo kit off and the transmission out so why not just go all the way with it. so i ordered all the paint in OEM color in spray cans. primer, Y01 lightening yellow, and clear. it wont be a professorial job but it will look a hell of a lot better then it does now. im excited to get started on this.
thanks to streetthisevo for your help on setting me up with what i needed
Hope it turns out well for ya! The warmer you can get the space your painting in the better. My car was way to cold to paint when I did mine.
Old Feb 5, 2013 | 06:58 AM
  #78
06MREvo's Avatar
facebook.....
Old Feb 5, 2013 | 07:01 AM
  #79
Wheatley's Avatar
Prep is almost all of it. Ajax and a scotchbrite pad go a long way.
Old Feb 5, 2013 | 07:07 AM
  #80
NODAKevo's Avatar
ET is the only company I would trust with my car. Can't beat an Ebay turbo housing.
Old Feb 5, 2013 | 07:49 AM
  #81
EvoDan2004's Avatar
My garage is heated so I hope that helps. The plan is to push the car outside and powerwash the engine bay and clean it. Then push it back inside and hand sand it with 600 and 800 grit sandpaper. Then push it back outside and clean it off. Ill be painting it outside but once each coat is done it will be pushed inside to dry
Thanks I will give it a shot. Im no pro but with some time and patients I think I can do this.
As for ET products. Id rather shop at walmarts automotive department. Haha
Old Feb 5, 2013 | 08:28 AM
  #82
SSsshhhhhhhh!!!! Don't give away their top secrets!
Old Feb 5, 2013 | 10:18 AM
  #83
Wheatley's Avatar
The oem engine bay isn't clear coated so it only needs a scuff to make paint stick. Actually thats all paint needs over clear coat as well. If you use the scotch brite and ajax it will clean and scuff at the same time. I would first degrease the engine bay and power wash if you want. the next is to scuff. We usually use red pads. You will rinse again, reg hose pressure is fine. If you have any areas that have had ethanol or other oils pay special attention to them. Prime any bare metal spots. Buy a tack rag from your local paint or parts store. After cleaning several time tack it down before spraying. You know the rest of thin light coats is key.
DO NOT use wd40 or any other silicone containing sprays in the garage or in the house for several days before clearing. I'm unsure if the aerosol clear could be effected but standard automotive clear fish eyes like a **** if that **** is even misted in the area.
Old Feb 5, 2013 | 02:02 PM
  #84
EvoDan2004's Avatar
great info. thanks. i will go out and get the red scotch brite pads and some AJax. that is the white powder stuff correct?
as for the tack rag i do not understand what that is. is it a special rag i wipe the surface down with before i prime?
thanks for the tips. it will for sure come in handy.
Old Feb 5, 2013 | 02:25 PM
  #85
Wheatley's Avatar
Yes and it'll be labeled Ajax a tack rag is something that is well tacky lol. It'll be in the paint section of most decent automotive stores. When you open it it'll feel sticky. Open it up and wad it loosely. It's used to remove lint,hair and fine dirt from the surface. Before you dive in there are a ton of videos on YouTube and write ups all over. I worked in a body shop for a while and hung around for years after. This is how I did mine and how I've been taught to do most surfaces. Biggest thing is prep.
Old Feb 5, 2013 | 02:28 PM
  #86
EvoDan2004's Avatar
ok great. im hitting the store tomorrow and thanks a lot. i got a engine hoist on its way over to my house friday. i hope to have everything out of the engine bay in 2 weeks.
Old Feb 5, 2013 | 06:35 PM
  #87
EvoDan2004's Avatar
i am pretty bored so ill post my progress because i have no life. tonight i removed the C.O.P., coolant over flow, UICP, intake, battery tray, and unplugged the crank sensor and front o2. that is all. back to watching TV and eating apple sauce.
Old Feb 5, 2013 | 08:22 PM
  #88
Wheatley's Avatar
I should have had apple sauce instead of working on my pile.
Old Feb 6, 2013 | 02:20 PM
  #89
EvoDan2004's Avatar
i love apple sauce. LOL
when i get home tonight i may pull the radiator, fan and both front fenders. then eat more apple sauce.
Old Feb 6, 2013 | 03:17 PM
  #90
R/TErnie's Avatar
Im interested in seeing how the paint job turns out. Like they say... it's all in the preparation!
