Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Mar 2, 2014 | 04:58 PM
  #1066
EvoDan2004's Avatar
Originally Posted by aggieEVO
I saw something about bent valves and freaked out that maybe I missed a blown motor. Phew.
Keep up then incredible work.
the motor ran amazingly before i took it apart. i wanted to freshen it up some and change CR. i dropped the head off expecting a good bill of health and only looking to have it cleaned and some port work done on the oil return holes. i was told the guides were shot. so i ordered new ones. then i was told 8 exhaust and 2 intake valves were bent. not enough that the eye could see but when put in the machine he said he noticed it. they are a local shop and have good feedback so i figured it is not rocket science to clean up a head. i am second guessing this choice but i guess at this point it is what it is so we will see what happens.
Old Mar 5, 2014 | 04:05 PM
  #1067
EvoDan2004's Avatar
well here it is. PST one piece carbon fiber driveshaft. im going to do a complete review on this. weight, install, and beat the crap out of it on the street and track. lets see how it works out. more to come.
i ghetto scaled it. i am pretty sick so moving around sucks and i wasnt pulling out my good scale. so i weighed my self on the bathroom scale and then weighed my self holding the driveshaft. i got 16.8LBS. i will get a accurate number shortly but PST advertizes it at 17lbs
Old Mar 6, 2014 | 03:08 AM
  #1068
EVO8_PR's Avatar
Looks beautiful, it's a shame it has to go underneath the car.
Old Mar 6, 2014 | 06:48 AM
  #1069
06MREvo's Avatar
^^^What he said!
That's a nice shaft you have there EvoDan
Old Mar 6, 2014 | 04:04 PM
  #1070
mitsubeastlee's Avatar
how much did the awd 2 piece weigh?
Old Mar 7, 2014 | 12:20 AM
  #1071
jeffbeagley's Avatar
Originally Posted by 06MREvo
^^^What he said!
Old Mar 7, 2014 | 03:48 AM
  #1072
StreetThisEvo's Avatar
I'd touch his shaft....just saying haha.
Old Mar 7, 2014 | 05:11 AM
  #1073
d-bo's Avatar
i just installed my carbon driveshaft as well. incredibly lighter
is that a full 1 piece DS then? i have a torqline one so it makes the 2 rear sections into 1 piece. i wonder how much of a difference it is between the 2.
Old Mar 7, 2014 | 07:20 AM
  #1074
EvoDan2004's Avatar
look guys. i dont mind you looking at my big black shaft. but when you all come over to pet it we need to do this while my fiance is not home. she may wonder why 5 guys including my self are under my car making odd sounds.
as for weight like i said i ghetto scaled it and it was 16.8LBS. today i will scale it on the good scale. this is 11lbs lighter then my 2 piece driveshaft
yes this is a complete 1 piece driveshaft.
Old Mar 7, 2014 | 07:52 AM
  #1075
06MREvo's Avatar
Originally Posted by jeffbeagley
lol, you jelly?
haha, exactly!
haha, I'm sure we could fit 5 guys under there at once. And honestly, I'm pretty sure Lisa would be fine with it...
Old Mar 7, 2014 | 02:24 PM
  #1076
EvoDan2004's Avatar
well finally the second batch of my custom made TI axle nuts have arrived. i got to install my set today. here it is on the rear of the car.
Old Mar 7, 2014 | 03:02 PM
  #1077
kpt6's Avatar
Awesome DS, man. I didn't know one this light even existed for the CT9A. Are there drawbacks to a 1 piece?
Old Mar 7, 2014 | 03:27 PM
  #1078
EvoDan2004's Avatar
Besides removing the carrier mounts I do not know. We are going to find out
Old Mar 7, 2014 | 07:59 PM
  #1079
detroit pistins's Avatar
That's almost 20 lbs worth of saving over the stock unit isn't it?...let us know how it works out.
When the geometry of a rotating shaft is modified, it can run into a risk of what's called "shaft whirling".... this behavior is basically caused by its center of mass rotating "away from the center line"...etc
They are using a single long piece instead of the stock design which is supported in multiple places (for better control), however, it is made out of carbon fiber so the deflection and mass properties had changed as well and whirling may be avoided at least for his setup (gearing, rev limit...etc)
Old Mar 7, 2014 | 09:04 PM
  #1080
EvoDan2004's Avatar
closer to 25/26lbs lighter then a STOCK driveshaft.
PST claims to have similar sized shafts on other cars that have documented over 180mph without vibrations or issues. each driveshaft is specifically made per order per that persons setup, hp, trq, speed, ETC. these are not a in stock type idem. 100% made per order as they see fit. i am confident it will work and in the event it does not work i have the ability to send it back and i will slap on a DSS 2 piece carbon.
my car also has a solid front cross member, avid 80D engine/trans mounts, and i also have the light weight rear diff brackets. so engine movement is nearly nothing. on the dyno when the car hits full TRQ ''over 650'' i do not see the engine move. that does not mean it does not move but its a good indication on how things are doing. i DO NOT recommend this 1 piece shaft on anything OEM mounted.
