razorlab's simple build(s)
Old Mar 2, 2015 | 10:25 AM
  #166
rcb213's Avatar
Originally Posted by razorlab
Then you just talk to hard parkers with nexus tires or have a data set of less than two.
I'm not going to argue about something I now about with utmost certainty.
And I'm not going to argue with you lol, you know much more than I do. I was just stating the numbers I saw. My bad if I came off wanting to prove you wrong.
Old Mar 3, 2015 | 10:54 AM
  #167
jayyyw's Avatar
I run direzza star specs 265/35/18 on 18x9.5 +22. No rolled fenders. I'm about 56" FTG all around and only rub in the rear on hard bumps.
Old Mar 3, 2015 | 11:44 AM
  #168
RazorLab's Avatar
"only rub in the rear on hard bumps."
That's rubbing.
+15 would be even worse.
Btw, measuring fender to center line is a better, more accurate way.
Old Mar 3, 2015 | 12:58 PM
  #169
momostallion's Avatar
I'm assuming you are talking about the Enkei RFP1 in 18x9.5 +15. I can guarantee you that anybody with 265 AD08R's, ZII's, RS3, etc will have to roll the rear fenders.
this guy knows what he is talking about in general and this topic is no different.
i have that setup (265/35/18 Michelin PSS on enkei raijin 18x9.5 +15), even with -1.75* camber, i very much so had to roll my fenders. when i was on swift spec r springs it was very apparent, once on ohlins with 600# rear spring, not anymore.
the only way you wouldn't is some combination of the below:
if you are stock ride height
never put anyone in the back seat
run a crap ton of negative rear camber
run very high rear spring rates
Old Mar 8, 2015 | 01:44 PM
  #170
RazorLab's Avatar
Guess what.... I FIGURED THIS SOB FUELING ISSUE OUT!!!!!
I started tuning the car on 91 octane since I'm going to track it on 91 and the AFR issues where just bugging the hell out of me. Sometimes it would be lean, sometimes rich, sometimes the AFR would just stick.
Basically all the stuff I posted about before, driving me nuts, especially on the less forgiving 91 octane fuel.
On a whim I decided to rewire the power for the Zeitronix. Before I had it tapped into a power wire on the passenger side. This time I decided to use a Add A Fuse like I did with my Sportback. I ran the wire to the interior drivers side fusebox, and used the Cigarette lighter fuse position. (7.5A)
Started the car up and guess what, the gawdamn thing works perfect now. It responds to throttle changes like a proper wideband and never sticks.
Can't believe I've been so lazy not to check this simple thing. When I did a couple pulls yesterday on 91 octane I couldnt get the car to go richer than 11.8 AFR, and it would only show that a couple times.
After rewiring today. WOT now instantly drops to 10.6. Haha. Now it makes me wonder wtf AFR I was running on E85, probably pretty rich, which would ALSO explain my high IDC's.
SMH. I can be a lazy idiot sometimes. So glad I finally got this working correctly.
Old Mar 8, 2015 | 02:08 PM
  #171
WWGSR's Avatar
Do you do etunes?
Old Mar 9, 2015 | 07:09 AM
  #172
mrfred's Avatar
glad you figured it out.
this is an interesting commentary on how companies design their wideband controllers. while zeitronix and, i suspect, aem controllers will spit out inaccurate afr values, an lc-1 would have errored out. of course the biggest gripe out the lc-1 is that it errors out.
Old Mar 9, 2015 | 07:19 AM
  #173
RazorLab's Avatar
this is an interesting commentary on how companies design their wideband controllers. while zeitronix and, i suspect, aem controllers continue to spit out afr values, an lc-1 would have errored out. of course the biggest gripe out the lc-1 is that it errors out.
I also wish that they would tell you the controllers need a strong power source. I had no idea. I thought power was power, apparently I was incorrect but electricity has never been my strong field either.
Old Mar 9, 2015 | 07:29 AM
  #174
mrfred's Avatar
yeah, the heater in the wideband can pull up to 5 amps. its not a lot, but its not a little either. if the sensor can't maintain temperature, ...
Old Mar 9, 2015 | 12:11 PM
  #175
alpinaturbo's Avatar
I was quiet taken/surprised when you went for Ambit...
The NTO3+M look awesome and are proper track-wheel, coupled to great Yoko tires - you can drive to track enjoy the track, and drive back, with the same tire/wheel. Makes it for a great day without stress and hurry to mount track tires. Arrive and Drive!
Old Mar 9, 2015 | 02:11 PM
  #176
RazorLab's Avatar
Are you going to be at Thunderhill on March 22nd?
Old Mar 9, 2015 | 03:20 PM
  #177
jayyyw's Avatar
That's rubbing.
Sorry, I wasn't trying to contradict what you were saying.. Just throwing out a little "nugget", so they say.. I just recently cut the inner lip out, instead of rolling the fenders. I no longer have any rubbing issues, even with the 5mm spacer I added, all around.
Old Mar 16, 2015 | 08:41 PM
  #178
RazorLab's Avatar
I've been fine tuning the car on 91 octane at low boost for the track.
I have something that I'm leaning towards it being a boost leak somewhere. Wanted to post this to the forum and use you guys as a sanity check.
So here is the car on a single 3rd gear pull from 3K. Notice the WGDC numbers and the dip and noodley mid range.
http://datazap.me/u/razorlab/singleg...&zoom=886-1052
Now, take a look if I do a more normal quick stab to WOT in 3rd at around 4K:
http://datazap.me/u/razorlab/3rd4thp...-3&zoom=12-224
Crazy boost spike then immediate drop to 17psi (even with not much WGDCc) and bigger boost spike after the shift with another big boost drop.
This is text book boost leak right?
Old Mar 16, 2015 | 10:48 PM
  #179
mrfred's Avatar
I used to see that kind of behavior when I was running stock exhaust. As soon as I swapped to a TBE, the wavy boost response went away.
Can't you do a boost leak test?
Old Mar 17, 2015 | 07:30 AM
  #180
RazorLab's Avatar
Yea I do know what you are talking about, however, did you see the second log with the 9psi+ boost swings?
I don't work at the shop anymore so I don't have access to a compressor and other things. Makes it a little harder nowadays.
