razorlab's simple build(s)
#887
Not sure the best way to measure effectiveness for you guys. It doesn't seem crazy hot after driving the car around town. True test is whenever I make it back to the track.
The shielding itself is very light. If you have ever held a piece of OEM inconel shielding (like on the Evo X firewall or on the chassis above the exhaust), it's basically the same.
#888
that does sound like mechanical noise and not knock... When I did the GSC S2 install Aaron told me to adjust the knock tables to get rid of phantom knock.. Glad it seems to be working out for you too..
#890
I left my laptop at home, I will take a look when I get back..
#891
Oil feed fitting at the turbo (the one that was loose) is now officially leaking. Coated the center cartridge housing, luckily I smelled it and checked before it had a chance to catch on fire.
Car is now garaged until the shop that put it together gets back from his Europe trip. :-/
Good side is now I have a bunch of time so I can swap the intake manifold and throttle body and install the secondary knock sensor.
#892
That sucks man. I don't think I would have the patience to let the car sit lol
#893
It's also SUPER frustrating that I can't just unscrew the damn fitting or simply tighten it.
I was actually to the point of brainstorming last night how I could dremel cut the L part off enough to allow the fitting to turn without getting any shavings into the turbo. lol.
If I didn't have the luxury of having a second fun car I probably would have gone postal by now.
#894
shove some grease in it and cut it LOL. Get a straight fitting, and a line with a 90* swivel.
#896
It would work. Use a grease needle to make sure it gets fully filled up.
#897
As far as turning the knock sensitivity up, Its needed as the engine goes farther from the way Mitsubishi built it. Aftermarket pistons/rods/cams are going to change harmonics.
Can you stick it on the dyno on low smoothing and run the timing up/down to see what it likes. If you needed to test the sensor/real knock you could purposely knock it at low boost if you wanted to.
It would save alot of time and you would have a clear answer on the engines performance. Its alot easier to see exactly whats happening on a dyno vs road logs and ecuflashsums.
#900
The oil inlet has a large area to fill after the fitting. If it were to fill completely, some of the grease getting hot enough to flow wouldn't be an issue.
