MIL.SPEC lightweight 2.3 MR build
Old Feb 17, 2016 | 06:31 AM
  #121
brightside's Avatar
Originally Posted by Erik@MIL.SPEC
E85. 30-35 psi on the street, depending on what the car likes.
Well, the point of my build is threefold:
1) Lighten the assembly
2) Reduce friction
3) Contain/control heat
So, any kind of friction surface will have been treated in some way. Oil pump gears and shaft, bearings (main, thrust, bs), balance shafts, crankshaft and piston rings are WPC treated. Cams will be too. There's a moly coating on the piston skirts and I'll be putting a Techline coating on the cylinder walls.
I have the same thoughts for my DSM 4g63 build. I apply my own ceramic coating from cerakote as i own a powder coating shop. I've never used any of the techline product.
I really want to get my Gearset WPC treated.
Old Feb 17, 2016 | 08:06 PM
  #122
NexusEvoIX's Avatar
+1 for a built 6 speed
Old Feb 20, 2016 | 03:20 PM
  #123
Erik@MIL.SPEC's Avatar
Some updates.
Dropped off the assembly today to get balanced at Revco Precision. Talked to the owner Larry. He's been in the game a long time. Used to do all the Nissan GTP engines and later engines for Toyota. If you're in SoCal, he's the guy you want balancing your stuff. And since balancing is so cheap (about $100 on a I4), it's silly not to get it done.
www.revcoprecision.com
Ok, here are some more bits. MIL.SPEC rods before and after getting a Swain Tech oil shedding coating. Oh, and I have one more 150mm set left. Hit me up if you're interested. I'll give you a decent price.
Also, here is the Tomei wind age tray and crank scraper with the coating.
Should have everything back in two weeks and then assembly can start. Yay!
Old Feb 21, 2016 | 08:33 AM
  #124
Evo MR IX Fritz's Avatar
Some updates.
Erick how's that 6 speed holding up
Old Feb 21, 2016 | 10:35 AM
  #125
Well, the OEM lasted 175,000 miles with no problems at about 380whp. Sold it and purchased the Shep unit. It's been in a box until I get everything put back together.
Old Feb 22, 2016 | 04:33 AM
  #126
Jmills's Avatar
Hahahaha, that's the best slogan ever.
Old Feb 22, 2016 | 04:38 AM
  #127
spaggiari's Avatar
What do you think about modern nikasil coating on cylinder wall ?(I mean new age nikasl).
Old Feb 22, 2016 | 06:31 AM
  #128
Abacus's Avatar
IMHO, this is the pièce de résistance of the engine build, our Billet MIL.SPEC Pistons. 9.75 CR and the lightest weight Evo piston I've seen at 262 grams. These pistons were designed by Aby to not only have higher compression, but also proper dish (many HC pistons have flater tops). They're ceramic coated with a moly coating on the skirt. I plan on having the domes and valve faces ceramic coated too. More heat in the combustion chamber = more powa
Also went with a lighter weight DLC coated pin. Had them cryo treated as well since they're rated at 150hp/cylinder and we'll be bumping up against that with the Red on E85.
Also had the rings WPC treated for friction reduction.
What size are the pins? That turbo and 100mm crank will make alot of torque so upgraded pins are a good idea IMO. You mentioned they are rated 150 a hole. Using the 15% drivetrain rule that equals 510whp. You should easily make more then that. I'm picky about weight also but went with a .250 wall pin incase I get a larger turbo one day.
I'm looking forward to the 2.3 HTZ data, That thing should run good!
Old Feb 22, 2016 | 06:44 AM
  #129
spaggiari's Avatar
What is the name of coating on tomei baffle plate surface ?
Old Feb 22, 2016 | 07:32 AM
  #130
LetsGetThisDone's Avatar
Considering my stock bottom end is doing just fine at approximately the rated power of these pistons, I think he'll be fine.
Old Feb 22, 2016 | 08:36 AM
  #131
Oil Shedding Low Friction Coating. Read here:
http://swaintech.com/wp-content/uplo...ating-News.pdf
Since I am an advertising copywriter, I actually think it's a terrible tagline/slogan lol
Funny in a room full of guys. Not great from a brand perspective regarding a high-end engine builder/balancer perspective. Sounds like something he came up with a few beers in
Old Feb 22, 2016 | 08:53 AM
  #132
spaggiari's Avatar
Thank you for answer. This oil shedding coating must be the same as you have on your piston skirts. But what benefits this type of coating exists over DLC ?Sometimes we can find DLC coated piston skirts as well as pins. What was the main reason to choose this coating?
Old Feb 22, 2016 | 09:08 AM
  #133
Abacus's Avatar
We all push the limits, just sucks to find out the hard way after thousands have been spent on an engine build.
Old Feb 22, 2016 | 11:05 AM
  #134
The piston skirt moly coating was done by the piston vendor. Maybe the Swain Tech coating is the same as Swain's piston skirt coating, but it was applied to the rods for it's oil shedding capabilities.
Here are the piston pin specs. Not sure if cryo-treating them made a difference, but that's what I did:
Coating: DLC
Edge Type: Chamfered
Length: 2.250in
Nominal Weight: 106g
Outside Diameter: .866in
Outside Diameter Alt: 21.9964mm
Series: 94 Series
Type of Material: 9310 Nickel Carbon Steel Alloy
Wall Thickness: 0.170in
Wall Type: Straight
The wall thickness on the other pins was .230in., but those were heavy at like 123 grams a pin...which in my mind completely eliminated the advantage of saving 23 grams a piston with the billet units I have. Both those pins are made from case-hardened high-nickel carbon steel.
Old Feb 22, 2016 | 12:04 PM
  #135
spaggiari's Avatar
Thank you for answer i just want to understand what is better for oil shedding : DLC or this coating. I remember some articles with DLC benefits in oil shedding from different engine surfaces..
