MIL.SPEC lightweight 2.3 MR build
Ok. Finally some progress.
Got my SpeedSport Carbon/Carbon clutch. Flywheel is steel but friction surface is carbon...in fact, every friction surface is carbon. This should be able to take a lot of abuse. Flywheel is heavy though...like 20 pounds heavy. OEM is approx 15 or so. They have an aluminum option at like 10 pounds, but plenty of smart people have said avoid the lightweight version. However, after putting so much effort into making the whole assembly lightweight, I am reticent to throw such a heavy piece of metal on the end of the crankshaft. Thoughts? It looks pretty though
Getting the assembly balanced here. Recommended by Ed Pink Race Engines.
http://revcoprecision.com
So, after getting everything balanced, she'll be ready for assembly (FINALLY). Yay!!!
The Stock Evo8
Pressure Plate : 12.2 lbs
Clutch Disc : 4 lbs
Stock Flywheel : 13.2 lbs
Total : 31 lbs Bolted together
SpeedSport
Pressure Plate : 8 lbs
Clutch Disc : 1.2 lbs
Flywheel: says 20.5 lbs on an innaccurate scale. Taking into work tomorrow. But it's definitely heavy.
Total : Was told ~29 lbs Bolted together by SpeedSport
dont second guess . light fly is the worst thing you can do for an awd car. use it. you will be pleased. I run 33.5lbs in my ultra light 2500lb car. and the car launches/shifts/drives flat amazing.
To light and the car will not be as smooth, and will need to rely on electronics to keep rev's high for smooth shifting. You don't want your RPM's dropping to fast.
Those are lighter. Here are the weights. Clutch disc is super light.
The Stock Evo8
Clutch Disc : 4 lbs
SpeedSport
The Stock Evo8
Clutch Disc : 4 lbs
SpeedSport
All that matter is that the assembly is a bit lighter. You don't want to go too light as Jerry and Tom have said. I'm sure it will be fine with that weight.
Ok. Phew. FInally getting close to short block assembly.
Got my oil pump gears back from WPC. Has any other Evo owner done this? Looking forward to see how smooth and easily the engine runs
Also, got some ARP flywheel bolts and a Cosi balance shaft belt (I'm keeping my BS, but have done about as much as anyone can to ensure they don't seize up...including upgraded BS bearings AND had the BS and BS bearings WPC treated). That, short of the ER gear is about as much as I can think of to make sure the BS don't go kaput. And I think I'll enjoy the smoother ride. I don't enjoy sqeaky/noisy race car rides on the street.
Assembly gets balanced next weekend. Yay...
1) Lighten the assembly
2) Reduce friction
3) Contain/control heat
So, any kind of friction surface will have been treated in some way. Oil pump gears and shaft, bearings (main, thrust, bs), balance shafts, crankshaft and piston rings are WPC treated. Cams will be too. There's a moly coating on the piston skirts and I'll be putting a Techline coating on the cylinder walls.
