JR's 2.3L FP Black R2 Build
Old May 14, 2016 | 06:28 PM
JRally's Avatar
So 1.0 for this car started as an 03 Evo 8 wuth about 122k miles on the odometer and about 500 miles on a freshly built 2.3, rebuilt 5 speed and a rebuilt rear diff.
The previous owner decided that rather than ship the car from Washington to Hawaii he wanted to sell it, so I picked it up directly from English Racing where the first 500 miles were put on it by John Bradley/Midgespec himself.
Here's the rundown of how it was set up.
2.3L 4g63 with Wiseco HD, Manley H beams, Manley crank.
The head has GSC S2 cams and Kiggly springs and retainers
Turbo setup was just an FP black bolted to the oem manifold, 3" open dump, ETS piping and intercooler and an HKS SSQV.
Here it is when I first got it.
Old May 14, 2016 | 06:35 PM
JRally's Avatar
Bad ***** 2.0
After a short amount of time having it I did a few upgrades.
Synapse DV. If you don't have one, I highly recommend it
Delrin knob means no more burning my hand. And a little double din action for bluetooth goodness.
Next, I cracked a drilled rotor that came on the car, so some upgrades there.
Old May 14, 2016 | 06:42 PM
JRally's Avatar
Next, removed those ridiculous eyebrows from the headlights, wet sand and polish.
And evo 7 style red spray on the tail lights. Before and after...
Old May 14, 2016 | 06:50 PM
JRally's Avatar
After about 4000 miles, the brand new Comp stage 2 unsprung clutch went full on fail mode.
Here's a shot of the splines in the disc completely gone.
So, off to work me and my buddy went to install an ACT XTSS. I also had English surface my flywheel and give the transmission a once over while it was out. And everything in the drivetrain got new Redline fluids.
The new clutch is so much better. If you're choosing a clutch I'll recommend this one all day long.
Old May 14, 2016 | 06:53 PM
JRally's Avatar
Bad ***** 2.0
Immediately after getting back on the road with this thing, a girl rear ended me lightly creasing the bumper and dinging the trunk lid. After insurance approved repairs, the body shop was happy to swap me into a JDM rear. I paid the difference of $120.
I love how much shorter the car is, and a local muffler shop re-hung my HKS Hi-Power for $40
Old May 14, 2016 | 07:13 PM
JRally's Avatar
Retune time. I decided to ditch the mbc and put a 3 port solenoid in.
Picked up 14whp and 19wtq.
Bye MBC, anybody need one? I still have it somewhere.
Old May 14, 2016 | 07:18 PM
JRally's Avatar
Bad ***** 2.0
And that brings us to the beginning of 2.0
Doing the next version begins with another failure. The Manley 100mm crank the previous owner chose to use against advice from English Racing cracked. I noticed a light tick one day and though very faint grew a bit more noticeable after about a week. So I had English cut open the filter and drop the pan. Sure enough, cracked on rod journal #4
Old May 14, 2016 | 07:34 PM
JRally's Avatar
Bad ***** 2.0
So apart comes the car. Might as well do a bunch of stuff while it's down right?
Eagle has my new crank on backorder, so I've got some time.
Not much engine side is changing. Same motor, same head and just a trip to the machine shop.
Here's some shots tearing it apart.
Old May 14, 2016 | 07:50 PM
JRally's Avatar
Bad ***** 2.0
Old May 14, 2016 | 07:59 PM
JRally's Avatar
So I always planned to buy a daily, but this kind of forced my timeline. Found this 2000 Tacoma for 6k.
Went ahead and stickered it.
Decided to tear off the HKS Hipermax RS Coilovers to fund some upgrades. These are for sale if anyone wants.
Also got me some wheels. Ray's Gram Lights 57DR in 18x9.5 and I'm currently having them powder coated.
Old May 14, 2016 | 08:04 PM
JRally's Avatar
I've always hated having gauges on my pillar, so I removed this thing. Yay oem pillar!
I'm switching to the PLX multigauge and mounting it in an Ortiz pod I ordered.
Does anyone have a clue what this is. Tucked under carpet inside my center console.
Old May 14, 2016 | 08:14 PM
JRally's Avatar
So after talking to FP about the copious amount of oil that gets past these ball bearing turbos, I decided to use their new head feed line and I'll be addressing the crankcase ventilation issues as well.
And then while I was ordering that I saw this on sale, so why not?!
And if I'm going to buy that, might as well go down the road to Finish Line Coatings for some ceramic love, and hey let's take the turbine housing too.
And corroded bolts suck, so titanium hardware from Speed Factory, yes.
Old May 14, 2016 | 08:25 PM
JRally's Avatar
So being the brilliant dumbass I am, I decided it would be cool to tear apart the wiring harnesses and redo all of the looming to make them look nice.
...ugh.
Anyways, start small. This is the transmission wiring harness. Before and after.
Old May 14, 2016 | 08:35 PM
JRally's Avatar
This is the charge harness. Runs to battery, alternator and starter. Also had a plug for EGR in it, so I deleted that.
This is a little ground strap that runs firewall to intake manifold.
Old May 14, 2016 | 09:15 PM
JRally's Avatar
Stayton Peterson to the rescue with his mad headlight modding skills. Looking so good now. Did you know oven cleaner takes chrome off of plastic?
