Group Evo IX Engine Build
Old Apr 27, 2018 | 07:32 PM
  #61
2006EvoIXer's Avatar
Originally Posted by razorlab
You just stated the same thing in a different way. Just get the two tunes via two roms and flash between the two on the same ecu
Good idea.
Is there a limit to how many times we can flash our ecu?
Old Apr 27, 2018 | 07:44 PM
  #62
Originally Posted by 2006EvoIXer
Good idea.
Don,
Dont you have 2 tunes on your ECU now? Ive been dual mapped for just about 10 years. ECU has been flashed many, many times (at least 15 to 20x)
Old Apr 27, 2018 | 08:00 PM
  #63
Don,
Yes. I have 2 maps. Bryan is saying to get the 3rd tune on laptop so I just flash in before heading to Fontana and then flash back when done. Guess I can sell my spare ecu
Old Apr 28, 2018 | 12:35 PM
  #64
This is an interesting read. Makes you better understand and respect the rev limits.
http://blog.wiseco.com/how-a-stroker...-and-inertia.-
Old May 13, 2018 | 03:48 PM
  #65
Is there any website that has a list of all different piston specifications for quick comparisons? I'm looking for piston weights, wrist pin weights, measurements between piston tops to rings to wrist pins, and compression ratio.
Old May 13, 2018 | 05:31 PM
  #66
LetsGetThisDone's Avatar
Manufacturer's catalogs. I doubt someone compiled everything
Old May 13, 2018 | 05:45 PM
  #67
Is this something they can email me if I ask? Or does my machine shop have to request for their catalog?
Old May 13, 2018 | 07:07 PM
  #68
They're on their websites...
Old May 13, 2018 | 07:24 PM
  #69
RazorLab's Avatar
Good idea.
I flashed my 2005 MR at least 100x. I flashed my 2010 RA at least 150x.
I don't think you have to worry about it.
You can also set up a dual map tune and just flip between the two without flashing the ecu.
Old May 13, 2018 | 08:16 PM
  #70
Biggiesacks's Avatar
so if you flip to page 687 of this bad boy https://www.renesas.com/en-us/doc/pr...3b3b0ff78dfff1 it states "Upto 100 times". This has got to be a minimum kind of spec. I lost the hard disk in one of my tuning laptops a while back but since 2013 i have reflashed my ecu 225 times, and i couldn't speculate how many times before then. One thing to keep in mind is unless you are changing the rom itself you probably are only rewriting a few specific blocks depending on what kind of changes you are making. So unless you change the same things over and over again its kind of spreading out the wear.
Old May 13, 2018 | 08:36 PM
  #71
Thank Bryan. I'll have my tuner tune for 24 psi boost for 91 and 28 psi boost for E85. I'll ask him to tune for 32 psi and 36 psi boost for E85 track days separately. That way, I can flash back and forth as needed.
I haven't decided if I'll use FP Black or FP Red (both MHI).
I guess it will depend on my compression when I get my engine back together. Was told my head will get done by weekend coming up
Old May 13, 2018 | 08:44 PM
  #72
Thanks Sean,
I'm trying to compare the differences between 150mm and 153mm rod/piston combinations and it's not very different.
Do you know which piston brand has the longest skirt?
Old May 13, 2018 | 08:57 PM
  #73
I originally wanted to max out my ported 71HTA with TurboSmart WGA. But at 51#/min, it's already at it's limits, so I doubt I'll get much more (maybe another 20whp). So since tuning is $$$, I'm just going to upgrade more.
I have FP manifold that I've polished. I also have FP Red and Black. I keep seeing Black hitting boost just as quick as Red, but Red makes torque about 1000 RPMs quicker while Black makes 60+whp more up top.
I need my stock bottom to hang on another 6 - 12 months so I can carefully build my spare engine to swap in. Then I can build my stock engine for long term. So I can beat on this spare engine and see what I'll change for my long life build.
Since my Tranny, TC, and read diff are generally stock, I'll probably limit the torque to 450-500 tq with built spare engine.
Old May 13, 2018 | 09:02 PM
  #74
By the way, how much power can AEM 320 LPH pump support? Do I need to switch to Wally 450? I have FIC 1650H (and resister bypass) going in soon.
I don't know if I'll run out of fuel pump with FP Red at 36 psi.
Old May 18, 2018 | 03:14 PM
  #75
Ran some calculations and compared loading between 150mm vs 153mm Pro H and the extra cylinder wall loads are about 3% higher with 150mm rods. For $250 difference on my spare block, I'll save it the $ for my block build.
Just ordered Carrillo MI-4G6T-65906S-04.
