Intermittent starting issue
Old Oct 6, 2016 | 03:50 AM
josh_evo9's Avatar
Originally Posted by JohnnyTSi
Yeah I did this probably about a year ago. Worked well for a few weeks. I'll double check to see if it came loose. Leaning towards a bad ground or a bad ignition switch.
Old Oct 6, 2016 | 03:23 PM
josh_evo9's Avatar
So I thought I fixed it today, found the ground wire at the intake manifold not even in the connector. The end of the wire was bare and just leaning up on the connector. Got about 3 starts on it and same issue. At this point I think I'm just going to replace the ignition switch.
Old Nov 26, 2016 | 07:55 AM
Chris Smith's Avatar
ignition switch
Old Nov 27, 2016 | 08:02 AM
josh_evo9's Avatar
I forgot about this thread. The previous owner had installed an aftermarket alarm system along with a turbo timer. The turbo timer was removed but the harness was still wired in. I had always wondered if the alarm was causing issues since the wiring under the dash was terrible. So I decided to take a few hours to remove the alarm system and the newly discovered turbo timer harness.
Since the removal I probably now have 70+ consecutive starts with no issues. The alarm was also causing a parasitic draw as that is no longer there. I removed so much electrical tape that my car should easily pick up a tenth in the quarter lol.
Old Nov 27, 2016 | 11:58 AM
barneyb's Avatar
What a mess!
Old Nov 27, 2016 | 02:17 PM
Cool that you fixed it. When people tell me they are having intermittent starting issues, my first two questions:
1. Does it have a turbo timer?
2. Does it have an alarm?
One of those are usually the culprit LOL
EEV13
Nov 11, 2017 08:24 PM
nor11384
Apr 2, 2017 03:52 PM
chdvg
Lancer Troubleshooting
Oct 18, 2016 10:42 AM
ru4real
Jun 27, 2016 10:14 AM
