E85 / Ethanol This section is dedicated to tuning with ethanol.
E85 Gauge w/ output for under $100
Old Feb 2, 2017 | 06:24 PM
  #106
mrb00st's Avatar
Originally Posted by evo8tanner
Hmmm i may use cigarette outlet to power temporarily
You can use the DC Barrel connector to power with 12v
Old Feb 9, 2017 | 10:06 AM
  #107
wizzo 8's Avatar
Originally Posted by mrb00st
That is correct. No scaling at all like the patched roms. Just will simply switch maps once the output goes above the preset voltage trigger
What voltage is suggested for this? Also is there a way to add an led to this so it goes on when it switches to pump gas?
Old Feb 9, 2017 | 10:33 AM
  #108
ant_turbo's Avatar
Finishing up a smaller version of the E85 setup with a Arduino nano,, more compact
Old Feb 23, 2017 | 06:04 PM
  #109
killerpenguin21's Avatar
so i bought this board https://www.adafruit.com/products/1447 because i happen to be on the site buying the arduino...wondering if its still the correct board?
also, is the code on the first page still not set up for the 16x2? could i bother you for the 16x2 code if possible? Thanks!
Old Feb 24, 2017 | 02:34 PM
  #110
ant_turbo's Avatar
That one is fine. Just more wiring.. I bought a lcd with the dimmer modulator all ready installed. And only use 4 wires.
And u can use the Arduino clones. Work the same.just way chaeper.. here is what I use..
Stainsmart 1602 with the lcd dimmer in.built in.
And a arduino clome Elegoo uno r3
And yes the code is still for the 16x2 lcd
Old Feb 24, 2017 | 02:39 PM
  #111
ant_turbo's Avatar
O ya and if u want a much compact setup. Use the Arduino Nano.. and yes they do makes clones.. And they are under $10
Old Feb 25, 2017 | 11:10 AM
  #112
Yeah having some issues still, but will play with it more
Old Mar 6, 2017 | 05:32 PM
  #113
ant_turbo's Avatar
Hey mrb00st Do u know how to re-write the code for a oled 0.96 or 1.3,
Thanks.
Old Mar 26, 2017 | 01:29 PM
  #114
gixxer1621's Avatar
This is what i was looking for, nice write up. also has anyone done a gauge like this one
Old Jun 5, 2017 | 12:57 PM
  #115
mrb00st's Avatar
IM BACK! lol sorry for the hiatus. Took a new job and havent had a lick of spare time. I recently updated the library, some users were having issues with getting it to work. So i added 2 folders and u just drag and drop.
Old Jun 5, 2017 | 12:58 PM
  #116
mrb00st's Avatar
Thanks.
I have not yet gotten my hands on a oled screen. If you have one, shoot me over a pm and i can send u the code i have to test.
Old Jun 9, 2017 | 11:42 PM
  #117
evo8tanner's Avatar
Hey so I uploaded the code onto my arduino but when I wired up the lcd I am getting nothing. It does boot up and the screen lights up but no info is being displayed however my laptop shows that the loop is running and there is info being captured (0% eth. I think). We added the libraries from the folder linked in post #1. Any idea on the problem? Maybe I'm missing a proper library? Thanks for the help in advanced!
Old Jun 10, 2017 | 07:29 PM
  #118
mrb00st's Avatar
normally when this happens, your SDA and SCL wires are backwards OR the POT on the back of the screen needs adjusted
Old Jun 13, 2017 | 11:53 AM
  #119
evo8tanner's Avatar
Hmmm I adjusted the POT but I will triple check the wiring. Thanks!
Old Jun 13, 2017 | 05:26 PM
  #120
mrb00st's Avatar
If they doesnt work, u will need to check your I2C address. Using this here. This will spit out what the address of your I2C is so you can adjust it correctly in the code for the sensor
