Old Nov 19, 2017 | 02:26 PM
  #6466
EvolTweetyBird's Avatar
Popped the head off the motor. Look what 33 pounds of boost does to water when the head gasket gives up.
Going to have the new gouges welded up and then machine it back down. Amazingly both the head and block check out with a straight edge. New motor is ready to go in so this motor is going to get a full rebuild.
Attached Thumbnails 2026: What Did You Do To Your Evo Today?-evo-head.jpg
Old Nov 20, 2017 | 12:15 PM
  #6467
Boost doesn't do that, combustion does...lol. The same thing happens on NA motors.
Old Nov 20, 2017 | 12:50 PM
  #6468
Eric SlowEvo8's Avatar
ouch and drove it to work and soon enough it ill be put away for motor swap and bay painted
Old Nov 20, 2017 | 01:31 PM
  #6469
Moose_421's Avatar
Binary Seat Brackets
installed Binary Seat Brackets and I added washers between nut and brackets with blue Loctite which is not pictured.
While seats where out I decided to shampoo interior.
Old Nov 22, 2017 | 10:56 AM
  #6470
Moose_421's Avatar
Got a retune @ CBRD Speedfactory
A+ service!!
Old Nov 22, 2017 | 01:11 PM
  #6471
superbovine's Avatar
Put a much needed battery in my daily driver.
When I picked the car up about five years ago it had an interstate blem' battery that looked ancient (and they usually only last 6-12 months to begin with). Can't believe it still was working fine (though CCA down to 380) when I pulled it today. I felt bad, but it started leaking acid/venting far too much to keep it in there any longer. Had to be a blem' record, though.
Old Nov 26, 2017 | 02:42 PM
  #6472
Polished up the single stage areas of my paint, vacuumed a ton of dog hair out of the car.
Did a trial run with a generic back up cam to the FUSE radio with success... except the cam isn't mirrored so no install today.
Realized i need to reupholster the seats, ordered some recaro print and fake alcantara, need to decide if I should try it myself or just sublet it.
Cleaned the steering wheel finally so it's fairly soft again. Re-perforated the top section so it doesn't look all smooth anymore.
Old Nov 26, 2017 | 02:48 PM
  #6473
Bmurray's Avatar
Clay, cut, polish, seal, then wax
Old Nov 27, 2017 | 05:27 AM
  #6474
so clean,
did nothing but warm it up. headlights need to come off today to ship off on a trade and take car to shop and take out motor for a trade and turbo kit to post for sale
Old Nov 28, 2017 | 12:09 AM
  #6475
superhawk996's Avatar
Replaced my front corner light (actually both, since I switched them to LEDs). Nothing sadder than burnt-out light bulbs - it just makes me feel like I'm a lazy, apathetic car owner.
Old Nov 28, 2017 | 04:14 AM
  #6476
Evo9_Dubai's Avatar
Two weeks ago, I noticed my coolant was overfilling. Realized that it only happened when the car was going into boost. Did a boost leak test, all checked out. Changed rad cap, still the same. To avoid more problems, I removed the head, and noticed the HG was slightly damaged on Cyl 4. So boost was pushing coolant. Caught it early enough and no damage done.
Removed the head.
new HG !!!!!!
Old Nov 28, 2017 | 05:21 AM
  #6477
glad u caught it early, which IM is that?
just took lights off to ship on a trade and added dark side markers.
Old Nov 28, 2017 | 05:58 AM
  #6478
Evo9_Dubai's Avatar
Originally Posted by eric slowevo8
glad u caught it early, which im is that?
ams vsr
Old Nov 28, 2017 | 06:18 AM
  #6479
oh ok never had seen it nice
Old Nov 29, 2017 | 10:59 AM
  #6480
Project_Broke's Avatar
Originally Posted by Eric SlowEvo8
Put the Evo x wheels on and washed it
This car is beautiful.
But if you don't paint those calipers right now, I'm going to do it when you're sleeping.
