Lancer Aftermarket Forced Induction Tech Discuss forced induction related specs and upgrades for custom aftermarket setups.
this is what happens when i get bored!
Old Aug 11, 2009 | 02:20 PM
  #151
bluebyu36's Avatar
good bro good
Old Aug 11, 2009 | 08:25 PM
  #152
JRR's Avatar
JRR
well i was finally able to get the 440's in there. havent had a chance to drive to drive it yet since the lower plate was leaking so i had to make a new gasket for it, and will refill tomorrow morning.
although i did start her up to see if it would idle with the 412 scaling that senate suggested. it idled but when i gave it a little gas it seemed to want to die. here are the latencys that i had:
should i go up down and by about how much you think?
and yes i will go out and try it tomorrow, once i get some fluid in the trans.
josh
Old Aug 12, 2009 | 10:17 AM
  #153
JRR's Avatar
JRR
well finally filled the trans and drove the car with the 440's in there and no box. runs nice and smooth. boost is 12.2/ 12.0 or so. my idle is a little lean and 16.9/17.3 and that is what concerns me. i think thats a little too lean. anyone else have any ideas on that one?
Old Aug 12, 2009 | 11:52 AM
  #154
Chele's Avatar
Stock cam?
Old Aug 12, 2009 | 11:55 AM
  #155
Domolution's Avatar
Stock cams or maye 264 mini cams, baha!
Old Aug 12, 2009 | 12:18 PM
  #156
4g94T's Avatar
you need to add more latency in the 11v and 14v to richen the idle.
Old Aug 12, 2009 | 12:59 PM
  #157
Chele's Avatar
Well, I didn't see aftermarket cams on your build list, so let me chime in. The stock cam, Mirage cam and RRM cam suck for turbo vehicles. The lobe seperation is totally wrong and will throw off your wideband readings.
Old Aug 12, 2009 | 01:11 PM
  #158
JRR's Avatar
JRR
so your thinkin like +2% maybe?
ill do some data loggin tonite coming home from work and will post up.
yes i still have the stock cam in it. the last things i really have to change would be head, cam and pistons and rods. but im not sure if im gonna. its a daily driver. for the money into that i can put a nice downpayment on a awd gsx or somethng.
Old Aug 12, 2009 | 01:35 PM
  #159
4g94T's Avatar
Increment by .100 ms.
Make sure you tune the idle when it's in operating temperature
my rpw turbo camshaft is for sale!
Old Aug 12, 2009 | 03:07 PM
  #160
JRR's Avatar
JRR
got a price you looking for on that cam?
Old Aug 12, 2009 | 03:49 PM
  #161
4g94T's Avatar
Link is in the sig
Old Aug 12, 2009 | 08:03 PM
  #162
JRR's Avatar
JRR
well i adjusted my latencies a little from he stock ones. will send it to the ecu tomorrow afternoon when i get a chance to get to the ecu again.
Old Aug 13, 2009 | 06:51 PM
  #163
JRR's Avatar
JRR
got the latencies all figured out nd she idles like a charm and bost levels are in check. did a log thatll be posted up.
any reason why the whp in the log doesnt actually give me a reading?
this log is going arund the block with the eclipse 501 maf and 440's.
Old Aug 14, 2009 | 03:30 PM
  #164
JRR's Avatar
JRR
which latency value would i have to change if my car wants to start hard?
ever since i put the 440's in it has been a little rough to start my car, where i got to give it a little gas just to get it started, and just now it almost didnt want to start at all. i know the starter is good ive already looked and tested that.
Old Aug 17, 2009 | 09:12 PM
  #165
bzmotoninja83's Avatar
your maf dosent match the injectors? i dunno... i hace a 02 es and i heard that b4. also i had the same prob when me and a friend w a 02 eclipse switched maf's. we didnt kno that you have to flash the ecu..... i know you did but maybe this is the one post that makes all your crazy thoughts fall in to place.....HAHAHAHAHHAHAHAHHA
