2.3l 4g63 vs 2.4l 4g64
so 94awdcoupe your saying a built 2.3l 4g63 would be more reliable for me as a daily driver then the built 4g64 would be??
does sbr 2.4 motor use oil squirters?
thanks for your input!
I could spend 45 minutes taking a posting pictures of the boxes full of scuffed pistons I have in the garage. I have no desire to do that for you as in the end you will still feel eliminating squirters is a good idea. And there is nothing you can say that will convince me leaving them out is smart. dedicated drag cars can leave them out. street cars need them . Period. end of discussion for me. If you want to leave them out that is not gonna hurt my feelings.
Post one scuffed piston due to not having oils squirters and not poor machine/assembly work. Can you prove without a doubt the cause was lack of sufficient "splashing" of oil on the pistons or are you assuming.
You are making statements as fact. People on forums will believe those statements as fact. That is how the internet works. Now unless there is some massive difference between the basic operation of a 4g63 motor and a standard b series motor I honestly don't see why a forged piston should scuff the wall soo horribly that it would ruin a motor unless the motor was assembled wrong. Missinformation is a capital crime on the majority of forums I frequent. If you make a statement as strong and with as much conviction as you have made, then you should have some evidence to back it up in case someone questions.
^ why would you have a 2.3 when you can have a 2.4...
2.4>2.3
1) Cheaper to build
2) Better r/s ratio
3) Higher revs
4) 6mm taller deck allowing for custom builds
5) larger bore
6) More hp/tq
2.4L FTMFW
My soon to be MIVEC 10:1 2.4L Long Rod 156mm 87mm bore would walk the dog on your standard 2.3L any day of the week Rock! No pun intended...
I honestly think the 2.4L is the new EVO motor or the 4G64 2.2L Long rod for people still wanting to rev above 9.5k+.
Mikey
2.4>2.3
1) Cheaper to build
2) Better r/s ratio
3) Higher revs
5) larger bore
6) More hp/tq
2.4L FTMFW
I honestly think the 2.4L is the new EVO motor or the 4G64 2.2L Long rod for people still wanting to rev above 9.5k+.Mikey
Interesting post...I do agree with 94awd that oil squitters are good insurance and should help engine life...it is interesting that mitsubishi included them, but someone building a motor for even more power would leave them out...I also was concerned with wall thickness of 4g64 vs 4g63...
As I have received quotes to build both a 2.3 vs. 2.4, I am not sure how folks say the 2.4 route is so much cheaper. Folks have been going the 4g64 route for a long time now, some with luck and some without - head sealing being the biggest issue I have heard.
I would love to have 2.3L + that could handle power, last for 100K miles, rev to ~8500 rpm, and not cost $5K +...
What I am disagreeing on is his position that says the 2.4l should be skipped because the cost of fitting oil squirters, which are not necessary with a quality piston, prohibits it.
Having oil squirters is more than a reliability issue. The piston cools two ways. The piston rings transfer heat from piston to cylinder wall. The cylinder wall is then cooled by water jacket. The second is by the oil splashing on it from underneath. Removing the oil squirter is like removing half the piston cooling. this argument is no different than saying you can remove your oil cooler from car. Sure you can do it but it is not a good idea. The factory pistons from evo 4 and up have a cast in cavity under the piston. This is to allow the oil to stay on the piston longer. This transfer more heat to the oil for better cooling of the piston.
Forged pistons expand more than cast pistons. I have never, ever seen a cast piston scuff at the skirt from expanding too much. Forged pistons however expand alot when heated. I have maybe ten sets of ruined pistons from over expansion at the skirt. This only shows that forged pistons expand more than cast ones. So why on earth would it be okay to remove piston cooling from a piston that expands more than a cast one? Its not even a debate. its just plain stupid to say forged pistons dont need to be oil cooled. controlling crown temp is very important in a high performance engine. increase crown temps means lower detonation threshold as well.. Forged pistons are stronger than cast and can run at higher piston temps before melting, but that doesnt mean its a good idea to run them hotter.
I have no idea if sloboy 2.4 engines have squirters. I would hope it at least an option from them. But it wouldnt surprise me a bit to see it not available. sloboy is more about making a fast buck than they are offerring a quality product or good customer service.. I would buy my 2.4 from buschur if I couldnt make it myself.
Oil squirters are a no brainer and a good machine shop like Lesco that already has a CNC program for machining them in for $150.00 is also cheap insurance. When they are done it looks identical to an Evo block. Check out this thread and pricing is in post 21....also check out the special figure 8 copper o-ringing of the block and AMS makes a modified factory head gasket that goes with it for a perfect seal.
https://www.evolutionm.net/forums/ev...work-pics.html
can someone explain to me about the problem with the head to block seal, why are they not sealing properly?
how much thinner is the 4g64 wall vs the 4g63 wall?
i'm close to buying a 2.4l probably from buschur if they do build them, but i dont wait to make a move that ill regret later.. i appreciate you guy helping out
John
John
You typed a lot of stuff and I read it all. However...where is the proof that your scuffed piston was from lack of oil squirters not being present.
Sounds to me like your clearances aren't right. Once again. 1...single...solitary pic...of a piston that failed because of lack of oil squirters and not assembly error. Just one.
Yes it comes in 2 variants. A full custom billet Manley setup - Billet crank, rods, and pistons. Or stock crank, and Manley pistons and rods. I believe the stock rod shaves about $700 off the price total - However it might be more. David has one of these stock crank motors in the works. And my car was already at Buschur's when i lost the 2.0. Luckily I was only about a mile away.
Can we just put the oil squirters aside for now and move on? How about we talk about the water pump that has to be modified to work. Do we use the 4G64 water pump or the Evo pump and what exactly needs to be done in either case. Is there anyone that sells this as a plug and play part? How about how to modiy the top timing belt cam cover to bolt up the bottom two bolts?
Rod to stroke ratio DOES matter.
You can get a 4g64 in good shape and hone the cylinders round to meet the ptw clearance of a forged piston... you can keep a 86.5mm bore.
If you're competant with a mill and have access to machinery like I do... putting oil squirters in your block isn't rocket science.
I'm keeping my 4G63 Mivec engine as a longblock and building the 4g64 while mycar still runs. The block itself is MUCH cheaper than the 4g63 block... 150 dollars compared to 1000!
I picked up my 4g64 block and 94mm crankshaft for 650.00... You cant buy a 4g63 block for that. if I spend another 350 in machine work, I'm still cheaper than the 4g63 block w/out a crankshaft!
STD bore 4g64 is the way to go.
