272 cams...which valve springs
Old Apr 12, 2004 | 04:38 PM
Shahul X's Avatar
to all the 272 cam users, assuming I get 272/272 cams.... (HKS)... I need valve springs and retainers.....right
What are you using....? I noticed most vendors dont have valvetrain kits on their sites... where did you all get them...who mkaes them and what are they made of
-SHAHUL
Old Apr 12, 2004 | 04:56 PM
Quickshift's Avatar
Hey talk to David he sells a nice set of springs for an awesome price. I got a set of them and they look very good. Cant beat 200 bucks for some titanium....
Old Apr 12, 2004 | 05:05 PM
WannaRace's Avatar
Shahul, you getting the cam gears too and going Silver's route?
Old Apr 12, 2004 | 05:08 PM
stvbreal's Avatar
You don't realy. At least I didn't change them out. If you get Piper cams then yes you will need the get them.
Old Apr 12, 2004 | 06:03 PM
Shahul X's Avatar
I think for 272's I just wanna be safe about it, plus it cant hurt
Wannarace: yea, I think Im gonna try Silver Surfers method.... 272/272 w/ cam gears set to -4/ -1 ..... I just noticed most people have "cam packages" that have cams, gears, fuel pumps etc.... but no optins for valve springs and retainers....
I never thought about the Bushure ones, THANKS also Quickshift!
-Shahul
Old Apr 12, 2004 | 06:10 PM
sccavee's Avatar
Just had 264/272 installed by Buschur and did not change springs. I would look at theirs if I did though.
Shahul X's Avatar
wow, nice , your right $200 for vavlesprings and retainers.... cant beat that..... ferrera is twice that almost
-shahul
Old Apr 12, 2004 | 06:11 PM
en1gma19's Avatar
Quantum racing has a ferrea valve spring kit for $519 which include double valve springs, titanium retainers and locators. They also sell ferrea valves either stock size, or 1mm oversize for $320. Hope this helps
Old Apr 12, 2004 | 06:14 PM
evo542's Avatar
you can just buy the regular HKS springs, i know boost-soultions sells them http://www.boost-solutions.com/evoEngineSprings.htm
Old Apr 12, 2004 | 06:41 PM
Z1 Performance's Avatar
we have tried the HKS and they did not fit
Old Apr 12, 2004 | 06:46 PM
chickenbrest's Avatar
I got Buschur Stage 4 with 264/272 HKS cams and to the best of my knowledge, they did not change my springs and retainers. I would assume that they would have changed them if it was necessary.
-Doug
SSKILLA's Avatar
so do we really need cam gears with 272's????.........
im going for the sleeper look
what do u guys think.......is it needed ?
Old Apr 12, 2004 | 07:04 PM
Buschur told me that cam gears were not needed and that they did not recommend them. However most of the other vendors I talked to use them. I have read here on the forum that you can smooth out your idle with them.
Buschur did my complete setup and tunning and I definately notice that there are different cams in there now and the idle is a little lumpy but it is not bad at all.
Old Apr 12, 2004 | 07:30 PM
bishiboy's Avatar
If you are going for the sleep look, keep the timing belt cover on and nobody will know you have gears. And the gears will help with the lopey idle, but you sacrafice topend HP.
Old Apr 13, 2004 | 07:16 AM
ShapeGSX's Avatar
You don't need stronger valve springs for HKS 272s. I'd say that changing them out is actually more dangerous than leaving the stock ones in. You never know what might go wrong when working on the head.
