Camp Lejeune/Jacksonville Evos
Old Dec 27, 2008 | 04:00 PM
  #2836
E VOL IX's Avatar
yes it will be just fine
Old Dec 27, 2008 | 04:17 PM
  #2837
Jeovannie's Avatar
i tapped my afi mani and that motherfu(ker is thick
Old Dec 27, 2008 | 05:15 PM
  #2838
Psquared's Avatar
I know...that's what i'm affraid of. It's going to be a pita...what sensor/brand are you guys running? Was it a standard npt thread...like 1/8" ?
Old Dec 27, 2008 | 05:18 PM
  #2839
E VOL IX's Avatar
yeah... just use a pilot bit and a step bit
Old Dec 27, 2008 | 05:28 PM
  #2840
Jeovannie's Avatar
my egt is the the one for zeitronix
http://www.zeitronix.com/installatio...stallation.htm
Old Dec 28, 2008 | 06:49 AM
  #2841
Psquared's Avatar
Well i'll be doing the egt too here soon. The biggest pita is the damn idle problem still. I have been surfing the boards for an hour reading other peoples issues. All describe the same thing, but none have found a solution. Jason said my fueling was good...but my afr's are whack. I know everyone says vacuum leak. I put a new gauge in and you can see it holds some vacuum, but it does loose it when the rpm drop. I've boost leak tested and everything holds fine. If a egr hose or something was off...wouldn't it be obvious when it's pressured to 20+psi? wtf...
Old Dec 28, 2008 | 06:52 AM
  #2842
Psquared's Avatar
Someone suggested the coolant temp sensor. When the car is warming up at a high idle everything is fine. Once it reaches that magical temp and the car goes into the lower rpm idle, it all goes to h*ll. Lopey idle trying to stall...idling at 10 afr's.
I haven't swapped that new front o2 sensor in yet. What's strange is the car is throwing a cel saying the front o2 has no activity, but evoscan is recording .7-.9volts solid. Which is right?
Old Dec 28, 2008 | 06:58 AM
  #2843
nymike0731's Avatar
hey bob i still have the o2 for u from jason call me so we can meet up
Old Dec 28, 2008 | 07:06 AM
  #2844
Psquared's Avatar
I will when I'm around...
Old Dec 29, 2008 | 06:16 AM
  #2845
Psquared's Avatar
Anyone heard/seen this stuff...
http://www.techlinecoatings.com/hi-performance/
I ran across it on a *cough..cough* subbie forum...
Old Dec 30, 2008 | 06:55 AM
  #2846
Psquared's Avatar
Im picking up an APS twin vent bov. Read nothing but good stuff. My stocker IX starts leaking at 6psi. It fails.
Old Dec 31, 2008 | 12:04 PM
  #2847
ch53avitech's Avatar
Leave for Iraq Monday. Woot! I already have a shopping list made. It's not long. Clutch, Red, Injectors. Exedy HD clutch, release bearing, and kelford 272 cams shipped to the door for $2100 from Maperformance.
Old Dec 31, 2008 | 12:56 PM
  #2848
Brian_08's Avatar
wow man, leaving at the coldest time of the year, thats not gonna be fun, if it gets as cold there as it does here in afghanistan i feel for ya man. everything is white here and COOOOOLD at least after the sun goes down, 40-50's in he afternoons, sumtimes 60's and teens and below at night. yea its COLD lol good luck man, be safe
Old Dec 31, 2008 | 05:34 PM
  #2849
Camp Lejeune has e85. You think they'll sell it to consumers?
Old Jan 1, 2009 | 06:42 AM
  #2850
bigric09's Avatar
Kelfords ? why ?
