Camp Lejeune/Jacksonville Evos
Holy sh*t..i'm about totally fed up. I just connected to the car 2 hours ago. Now, I update the xml file in evoscan and change 1 thing in my ROM, and now I can't connect to the car. I already searched a possible driver issue, but someone suggested that changing the xml could have affected it. I know the xml worked bc it opened a bunch of other items in my item list within ecuflash so I don't think I screwed that up. Ben, where is that ditch you were eyeing a while back?
+1
Change that D to a B and eye some of that
Bob, advice....
Start over. Completely uninstall evoscan, d/l and install the latest version.
Completely uninstall ecuflash, install the latest version. Either d/l or copy the ecuflash xml files from here or ben and load those in the appropriate folder. Open your rom and all should be well.
Bob, advice....
Thanks for your help and patience. I was so frustrated yesterday. I'm totally better today! lol
I uninstalled ecuflash and reinstalled. All drivers loaded successfully, I plugged in my cable and it loaded ok. I'm headed to the garage to test it out now..fingers crossed.
OK. Well that narrowed down maybe 50% of a problem. It still won't connect with ecuflash, however evoscan connects and logs perfectly fine. So, I guess that tells me the cable and drivers for it are fine. Here's the message it gives me. I don't ever remember all the zero's following my cable's serial #. Is that a problem?
[17:16:47.121] Using interface OpenPort 1.3 Mitsubishi TX14qc0X388f6900000000000000000000000000000000
[17:16:47.121] interface close
[17:16:47.137] unable to connect to vehicle interface.
I did ANOTHER full uninstall of every f-ing thing I can find that's associated with ecuflash. FTDI crap, tactrix stuff..everything. Did a restart and downloaded 1.42 AGAIN. Now, when I plug in the 1.3m tactrix cable it looks for a driver, then fails. I prompt it to look in the ecuflash folder where the drivers are and it locates 1 but gives me an error saying "driver not intended for this platform"
Sound like a bug with 1.42 download? All 3 drivers said they loaded OK when ecuflash installed..so now what. I don't have the patience for this.
Yeah, I thought I was going to outsmart it by switching over to my XP partition, and launching 1.29. It won't even connect, so I either locked the ecu somehow, or something else is up. I can data log perfectly fine. I did a FULL uninstall of ecuflash and every associated thing..ftdi drivers, openport stuff..everything. Reinstalled and same problem. I know I didn't have this issue prior to flashing a ROM with the v7 tephra stuff so I'm thinking that's the problem.
