Intake and Throttle body porting
Old Feb 5, 2009 | 08:44 PM
CGroovy2k2's Avatar
Sup Southeast! Sup Orlando! As a lot of you Orlando guys know, I'm in Iraq now and the problem I've just run into is since I can't decide on what turbo to go with I have the itch to do something else to the car until I decide on what turbo to go with. I've come to the conclusion to port my intake mani and T/B. Who do you (Orlando) suggest I take it to to have that done? Not worried about how long it will take as I can leave the car. Thats no problem. I just want to know who's going to do good work and at a fair price. How long does that procedure normally take?
thanks for the suggestions.
Old Feb 10, 2009 | 07:11 PM
CGroovy2k2's Avatar
Really? Theres got to be somebody who can shed a little light on the subject. Scott, do you know of a place? CFT? BVP? Anyone?
Old Feb 10, 2009 | 08:48 PM
xtremeboost's Avatar
Well , not many in town are set-up to do good porting - we used to have all the tools but now we just have out of state porting shops do that work for us . Many are running 600hp+ on 100% stock manifolds so you may want to look at turbo options first and worry about porting later . Just my 2 cents
Old Feb 11, 2009 | 03:12 PM
CGroovy2k2's Avatar
Thanks Xtreme. My goal is to get about 450-500 reliable hp out of it. once I get there I'll be happy. I hear you have a pretty good setup, what do you suggest (looking at what I already have and where Im at) my next steps should be to get there if porting isn't a must?
Old Feb 11, 2009 | 07:44 PM
The porting will not get you much at your power goals but , you can get a green and call it a day ! A larger turbo will get you the power goal you seek and at a good boost level without too much stress .
Old Feb 13, 2009 | 05:15 PM
CGroovy2k2's Avatar
i was looking at the red or the BBK for my next turbo. I hear a lot of good about the Red but like anything else I'm sure there is some bad. With the power that turbo has and can provide, I just want to be sure the engine will hold up. The BBK seems to be a bit milder of a turbo for the internals. Has anyone had problems with the Red yet? Blown engines etc?
Old Feb 14, 2009 | 10:41 AM
Either will work and also , even with a stock turbo I've seen people blown their motors . Blowing a motor is a matter of tuning for the most part and NOT the size of the turbo . If you want to make sure your motor holds up just follow these notes:
1 : be sure you have a safe tune ( fuel and timing )
2: Be sure you boost according to your fuel ( X - amount of boost for pump gas and X amount for race/meth )
3 : If you see something odd you get the car checked-out right away .
4: Use good oil and the right weight according to time of year ( temp ) .
If you keep those things in mind you should be ok for a long time !
Old Feb 14, 2009 | 03:10 PM
CGroovy2k2's Avatar
Well then I should be sitting pretty good then cause I do all those things already. Thanks for the input. Hope to meet you when I get back home. I told Andy I'm definately making a trip down for the weekend.
Old Feb 16, 2009 | 12:50 PM
I look forward to meeting you , Andy is a good guy - great guy to have as a friend
Old Feb 16, 2009 | 12:54 PM
alan678's Avatar
Not in your neck of the woods, but can be ordered online.....MIL.SPEC 65mm Throttle body and a Wilson v2 Manifold is a great combo.
Old Feb 16, 2009 | 05:34 PM
evo8fl's Avatar
+1 just, make sure you have the right parts and you will be ok
Old Feb 17, 2009 | 03:39 PM
CGroovy2k2's Avatar
I need to just get down to Orlando more often. 3.5 hour drive really isn't anything.
Old Feb 22, 2009 | 12:01 PM
apagan01's Avatar
waste of money for his power levels.
we have seen many evos make 600whp with stock mani and stock TB
supwiddiss
Cobb AccessPORT
Jun 24, 2016 01:21 PM
Ceramik
Southeast Region
Dec 9, 2015 07:23 AM
pistons4550
Sep 19, 2015 03:15 PM
EvoVIII_Tristan
Southeast Region
Sep 23, 2011 07:07 PM
RacinMylancer
West Region
13
Jan 23, 2003 02:21 AM
