Desperate need of good mechanic
Old Dec 6, 2011 | 05:54 AM
racing_girl's Avatar
I am in FL (Melbourne) I moved out here a year ago and my car is falling appart on me, I don't know good mechanics in the area so I have just been dragging the car along hoping it will keep it together but its feeling worst by the day.
Symptoms:
1- When i try to start it (turn the key) it will turn on the lights and ac and then make a winney noise but the engine never starts, I have to get on the key multiple times and give out 10 prayers before the engine gets power. (I assume is issue with starter)
2- It rattles at low rpm and when I go on first it will shake before actually moving.
3- If I go over 12lbs of boos it will miss fire and "jump" so I have to take it down.
4- Burning gas like a m.f. I am spending almost twice on gas and going slower, and its so bad when you stand next to the car at idle you could get intoxicated.
So in summary its falling apart I took it to cassels garage 2 months ago and they put new spark plugs in (crappy cheap ones) and it was better for about 1 week before falling apart again, if someone can recommend a good mechanic that knows about our cars I would really appreciatte it because most of the places I've gone just hook the car up to a computer and tell me its all broken because its not within the spec (which is obvious) since its been programmed and modded.
Sorry for the long post, all the help is greatly appreciatted.
Old Dec 6, 2011 | 06:08 AM
boostedtres's Avatar
Originally Posted by
Symptoms::(
1- When i try to start it (turn the key) it will turn on the lights and ac and then make a winney noise but the engine never starts, I have to get on the key multiple times and give out 10 prayers before the engine gets power. (I assume is issue with starter): [B
Probably a starter or ignition system issue. what kind of noise does it make when you turn the key and it does not start? clicking, nothing etc ? Whiney isnt really descriptive...sounds stupid, but youve checked the battery right?
[/B]
2- It rattles at low rpm and when I go on first it will shake before actually moving.: What do you mean "shake" ? Engine vibration, shakes when you engage/disengage the clutch? Whole car shakes? More info would help.
3- If I go over 12lbs of boos it will miss fire and "jump" so I have to take it down.: What do you mean by "Jump"? Do you mean spit, sputter, hit a wall, drop off in power etc? High RPMs and only when you boost. WOT or just anything over 12 lbs ? First and most obvious is the plugs. You said you got new ones, which is great, but useless if their gapped wrong, crap plugs, getting instantly fouled up etc. Pull them out and inspect for color/shape changes.
4- Burning gas like a m.f. I am spending almost twice on gas and going slower, and its so bad when you stand next to the car at idle you could get intoxicated.: Do you throw any CELs or check engine lights? If so, what ? Do you have an AFR gauge or have you logged it? Excessively rich I am assuming? I have had this problem numerous times, generally its from a bad 02 sensor causing the ecu to dump fuel in. If you or or someone you know can log it, do that and post it up.
There is a couple shops in FL. more importantly, there is one or two that I would highly recommend staying away from. You should do a search on here for florida vendors and get some more information before you take your car to any shop, or get more recs via PM from people here. Just a thought....
GL and keep us posted on how she comes along. cheers
Old Dec 6, 2011 | 06:25 AM
[/b] Everything turns on but its like it doesnt give power to the engine or the power is not enough to ignite fuel and turn it on, I have to turn the key multiple times and press it hard before I feel that it "engages" and starts up, it sounds like when you try to turn on a car thats already on, not sure how to better describe it.
2- It rattles at low rpm and when I go on first it will shake before actually moving.: What do you mean "shake" ? Engine vibration, shakes when you engage/disengage the clutch? Whole car shakes? More info would help. the whole car shakes as it moves forward when I get on the gas, I have to press in the clutch again and give it way more gas so I can take it out at a higher rpm else the engine shakes all over you can hear a knocking sound and it barelly moves forward, it sounds like I'm not giving it enough gas but ive had it for years I know it shouldnt do that.
4- Burning gas like a m.f. I am spending almost twice on gas and going slower, and its so bad when you stand next to the car at idle you could get intoxicated.: Do you throw any CELs or check engine lights? If so, what ? Do you have an AFR gauge or have you logged it? Excessively rich I am assuming? I have had this problem numerous times, generally its from a bad 02 sensor causing the ecu to dump fuel in. If you or or someone you know can log it, do that and post it up. The car is running ritch I have an AFR gauge but IDK anyone aroung here so "log it"
There is a couple shops in FL. more importantly, there is one or two that I would highly recommend staying away from. You should do a search on here for florida vendors and get some more information before you take your car to any shop, or get more recs via PM from people here. Just a thought.... Please PM'm me your input as far as shops, I really need to go see someone soon as I live in an apt and I barely get away with washing the car there so I'm sure they would most likely throw me out if I start experimenting with the engine.
Old Dec 6, 2011 | 06:44 AM
Spec-Ops1's Avatar
I know it is a long drive, but if you wanna come up to Jacksonville, I will take a look at it for you.
The starting issue sorta sounds like a weak battery, but if it making a grinding noise, it could possibly be the starter going out as well. Take it to autozone or advance auto parts and have them hook it up to there charging system tester, it is free...
The fuel issue could be a boost leak. If you have a boost leak the car will want to run rich, which will foul out the plugs quickly, and it will change the load the car will be hitting as well so it may be hitting boost cut because of this.
Also it could be rich as someone stated before, it may need a new front O2 sensor... I would have to log the fuel trims before making that determination.
The closest shops to you would be Titan Motorsports, Central Florida Turbo or Kings Performance in Orlando and AWD Motorsports in Coral Springs. You do not really wanna take the car to a joe schmoe garage as they will most likely not have a clue what the evo needs, will not gap the plugs properly, and you will pay for substandard service and parts.
Old Dec 6, 2011 | 08:18 AM
Balrok's Avatar
Pretty much what he said. Vac leaks are pretty easy to find with an air compressor and some misc parts if you have a friend that's local but just doesn't have an Evo. Search boost leak testers on here. I think they've got it down to $6 worth of stuff. I'd say it's both your batt and starter too, more so the starter with the post start death whine.
Old Dec 10, 2011 | 04:08 PM
EvoG8r's Avatar
I did some searching and this is what I found that is local that MIGHT be able to assist you. If nothing else, maybe they can point you at a Mitsu specific shop. Otherwise, you have to drive Orlando, Jacksonville, or SFL.
Grip Industries
http://grip-industries.com/wp/contact/
Melbourne, Florida
321-446-6644
Old Dec 10, 2011 | 04:20 PM
marcusE's Avatar
Clean your MAF senso out with MAF cleaner, change your COILS change your plugs to NGK brp7's gapped at you lowest .18 Check all your 02 sensors make sure they are still reading.. Log with a tactrix cable to do this.. Check your lines for boost leaks. etc etc etc Buy a new alternator check your starter by getting unde the car and putting a screwdriver in between the two screws on the starter. If your starter is good you will get a spark. Change your battery and then get a tune
Old Dec 10, 2011 | 09:12 PM
InfamousBoost's Avatar
my shop is located in Tampa if you don't mind the drive...pm me if you're interested.
Old Dec 11, 2011 | 06:45 AM
Update:
I took my car to cft last Friday, got a rental for a day (Sienna ) but luckily already have my evo back running goooood! It was as I suspected mainly starter and spark plugs issues among other tiny things they took great care off. Thanks everyone for all their help and to those who PM'ed me extra thanks as well!
Now, since it wasn't as bad as expected, I am on the hunt for a new clutch thinking CC stage 3 and a reflash after I brake in the new clutch, sounds like a good Christmas present to me
Thanks again
Old Dec 11, 2011 | 12:41 PM
2003evo8's Avatar
prs in sanford is close to u
Old Dec 11, 2011 | 03:05 PM
evoix16's Avatar
Ryu in springhill for stock ecu reflash!!!
Old Jan 17, 2014 | 07:43 AM
ExPhys31's Avatar
Anyone know good mechanics in Jacksonville, FL?
I know the thread is a couple years old. wanted to see if there are any updates on mechanics in Jacksonville, FL.
Thanks.
misha205
Nov 14, 2016 09:06 AM
Poltergeist
Lancer Troubleshooting
Aug 15, 2015 07:53 PM
SyHS
15
Aug 12, 2015 10:30 PM
KozmicMotorSpts
Nov 5, 2012 12:59 PM
EVO8_GSR
76
May 20, 2010 12:41 PM
