Ses P0123
Old Oct 27, 2004 | 12:32 AM
AKEVO8's Avatar
Ses P0123
Well I installed the EXEDE awhile back and finally got a ODBII scan tool. So I pulled the code for the SES it was P0123 Throttle/pedal postion sensor/switch a circut high input. This SES light has been on since the install of the EXEDE. It will not reset no matter how many times I try. I logged the TPS with the ODBII logger and it reads 100% no matter where the pedal is. Any help would be great.
Old Oct 27, 2004 | 09:16 AM
David@Vishnu's Avatar
I believe we talked on the phone? With the boost wire in the ignition spot? That would be something Id look at. RRE has a wonderful pinout on their site
Old Oct 27, 2004 | 01:30 PM
AKEVO8's Avatar
We haven't talked on the phone yet. But if the boost wire was in the ignition spot. Then I wouldn't get full boost would I? I am asuming that the other light green wire on the harness is the igniton wire.
Old Oct 27, 2004 | 02:02 PM
ez76's Avatar
Here's what David's talking about:
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Oct 27, 2004 | 02:11 PM
AKEVO8's Avatar
That is all fine and dandy. Without wire colors this does me very little good unless I am sitting in my car looking at the harness. I printed that out before you replyed ez76. But my question is there are 2 light green wires in the installation instructions if you mess up the install your car won't boost. My install is correct. So I guess my question is, is the harness wired incorrectly?
Old Oct 27, 2004 | 03:02 PM
No it shouldnt be wired wrong but please make sure the wire is 1.in the factory harness and 2. the integrity of the solder joints on the pnp are in tact
Old Oct 27, 2004 | 03:39 PM
AKEVO8's Avatar
That was more of the response I was looking for. Thanks David. I'll post my findings later today.
Old Oct 27, 2004 | 10:25 PM
AKEVO8's Avatar
Thanks for the help problem solved. That's what happens when you drink and install. LOL
tarheelsoldier
Mar 22, 2015 08:54 AM
LiX
Jul 13, 2012 07:23 AM
XRS-Lift
11
Apr 21, 2005 01:33 AM
CrazyIvan1978
Jan 12, 2005 02:36 PM
jabbawoni
May 27, 2004 11:15 AM
