Conditional How-To: SMART fuel threshold
Old Jun 5, 2006 | 09:02 PM
shiv@vishnu's Avatar
Here's another instructional how-to for those beta guys running the new conditional software...
For those running SMART, there is no no reason to have a separate SMART Fuel Threshold table (used to active/deactive the SMART fuel table). Now we can dictate the activation/deactivation thresholds with conditional parameters nested inside the SMART Fuel Map. What this means is there is one less table needed in a full SMART map (now 5 instead of 6). And since the Xede can hold 12 maps it in (divided into 2 banks), you can now have two fully SMART+meth/nls/etc,. maps at the flip of the switch. More importantly, you can now set up a much nicer threshold switch for SMART fuel activation/decactivation. Before, it was an RPM independant switch at 40% load. Now you can can contour the switch as a function of RPM (which is the ideal way of doing it since RPM will affect load).
Here's what you do...
Go to your SMART Fuel Threshold table. It's the one that has 0s in the top half and -100s in the bottom half. Right-click on it. Select "Delete this map." It'll ask you if you are sure. Say yes.
Go to your SMART Fuel table. Right-click and Select "Edit this map." Go to the Load Variable parameter and change it to AN1in (Wideband o2 input). Then go to Conditional Set up and configure it to look like this:
How this works...
This is a pretty simple one. It reads like this... Disable this SMART Fuel map (make it completely pass-through) if Load (aka MAF in aka Freq0in) is less than the load threshold curve down below for a period longer than 100 milliseconds (1/10th of a second). Notice that is is an ONLY conditional parameter. Not an AND or an OR. This means that only one condition (alone with the time parameter) had to be met in order for the map to be disabled. Once load/MAF/Freq0in is greater than the threshold curve, the SMART Fuel Table is active and doing its thing. You'll find that you can now have your SMART Fuel system working more often now wherease before it would only really kick on above 4000rpm under highish boost. Pretty easy, huh?
Cheers,
shiv
Old Jun 6, 2006 | 08:42 AM
Jorge T's Avatar
Works like magic!
Old Jun 14, 2006 | 03:59 PM
Jorge T's Avatar
nm
Old Jun 14, 2006 | 04:14 PM
donour's Avatar
sticky this maybe?
d
Old Jun 14, 2006 | 04:24 PM
Old Jun 14, 2006 | 04:27 PM
blast... i'm not able to do that. Grrr...
Old Jun 14, 2006 | 06:42 PM
Jorge T's Avatar
Imadumbass, just caught this today, I had not set Load Variable from User2 to AN1in. ...I gues my previous statement "works like magic" refers to Shiv's tune then
Needs to be a sticky
Old Jun 14, 2006 | 09:33 PM
Jorge T's Avatar
Now I do have lean protect and Smart conditionals activated...so far so good car feels quick. Noticed boost is spiking higher ... will have to log , does not make sense since it's a lot warmer and boost table was set when temps were in the 60s.
Old Jun 17, 2006 | 03:12 PM
Jorge T's Avatar
lean protect and conditional smart give No problems so far in 95+ weather, works like a champ.
Old Aug 14, 2006 | 01:51 PM
Evo23IG's Avatar
Bump for the pictures to work and this being a sticky......
Old Nov 6, 2006 | 05:43 AM
WhiteEvo05's Avatar
Did anyone archive post one so as to have the image showing the set-up for the conditional SMART fuel map?
Old Nov 8, 2006 | 09:40 PM
sspeed's Avatar
When will the "full..non-beta" version be available for those of us not as comfortable in our laptop abilities???
Old Nov 9, 2006 | 05:34 AM
Jorge T's Avatar
Here is an image of conditional fuel setup.
Attached Thumbnails Conditional How-To:  SMART fuel threshold-conditional-fuel.png
Old Nov 9, 2006 | 07:15 PM
WhiteEvo05's Avatar
Thanks, JorgeT!! Have a
Old Nov 9, 2006 | 11:45 PM
EvoTio's Avatar
When I tried to make my conditional fuel map, it looked a little different from yours, Jorge T. Please see my screen shot as an attachment. How do I complete the rest of the conditional fuel map? I also got a message that says "This feature has not been fully implemented" when I accessed the conditional map feature. Is it normal for that message to pop up? Also one quick question for Shiv. I am still using the original S.M.A.R.T. set up from the Tuning Technologies dyno day from 7/2005. Will this map work with that firmware or will I need to update to a newer version?
Attached Thumbnails Conditional How-To:  SMART fuel threshold-smart-fuel-screen-94.67.jpg
