New to xede
New to xede
Ok so i bought my evo a little while ago and it already had an xede in it i have added some other mods since buying the car but havent really messed with the xede, mainly because im not sure exactly how to use the xede. So i need some help, thanks.
Well, it will be best if you had specific questions so we can answer them for you. For starters you need a laptop to connect to the Xede.
Assuming your Xede unit was installed properly and has a good tune on it, then you are already using it.
There's nothing to do unless you want to change something about how your car runs.
d
EDIT: some more info:
http://www.xede.com.au/files/XEDE%20...20Version).pdf
d
your first mod, take it out and throw it out the window. My friend Xede is overheating for some reason. When driving the car with AC on everything works fine, once you turn it off and temp goes up the red light starts flushing on the xede ....
tcarretti
25
May 16, 2005 07:52 PM
