Break-in and car to car variation due to gas in oil
If you did not do this then smell your oil cap or dipstick and tell me does it smell like oil, or gas? If it smells like gas then I shouldn't need to tell you what that is, or why it's bad. Also why the cars make different power from one to another
Originally posted by 5StarSuzuki
Bah... I don't buy it. To many people stating it doesen't make a difference. Alot of shops build there engines, put them in the car and then dyno them at full boost.
If you could substantiate the break-in procedure by having the engine builders for Michael Schumacher explain it, then ok. Otherwise your countering the man who has built more DSM engines than anyone, Dave Buschur. And not to mention every other raceteam that rebuilds their engine inbetween runs.
I thought the last theory was spark-plugs?
Originally posted by DSMBRETT
The break in is one of the reasons we are seeing a discrepancy, not the only one. Boost differences between cars, possible build tolerance issues also play a part. As far as I know there has never been synthetic oil in any of the Evo 1-7, or the US Eclipse or Galant VR-4 from the factory. Someone correct me if I am mistaken.
As for the other cars (Porsche 911) most come with the motor already broken in, and the others such as the Northstar motor chew through oil at a pretty brisk rate. Mesinerboy did you check your oil?
erik
Originally posted by 2fast2Furious
I know they used to take the NSX and run it top speed to test it and that caused problems so now it comes with a break in oil that helps the motor and they say do not change it for about 4000 miles.
5Star- No one at our shop is forcing people to swap out their synthetic oil for dyno oil during break-in. It's simply a safe suggestion based upon what we've seen on the dyno and what we've talked about with reputable engine builders- both OE and aftermarket. If you want to say otherwise, fine. It's a free world.
My 2c,
Shiv
Originally posted by shiv@vishnu
Yes indeed. And as you mentioned before, another reason synthetic is used from the start in the EVO is for the turbo. It is reasonable to expect most EVO owners to not give the turbo the proper cool down it requires after a hard run. Since successive hot shut-offs will cause bearing coking and the resultant turbo failure (which is easy to diagnose and expensive for a manufacturer to fix under warranty), Mitsubishi went with the a synthetic oil to greatly reduce the likelihood of this happening.
My 2c,
Shiv
My 2c,
Shiv
I do understand why
went with Synthetic and most eng builders that I know do brake in a road motor with regular oil. There is no harm in runing a motor in with regular oil.Do you need to do this? Yes you should but no one is twisting your arm by any means.
I run full synthetic now and I feel the car is faster with it then with dyno oil.
My Very Best
Eric
Originally posted by Eric Lyublinsky
I would like to say That I did the brake in with regular oil for the first 2000 miles. I also make 241whp stock and also made good numbers after tuning and moding. A little stronger then other cars that I have seen. I'm Very pleased with the results. (I have not seen a drop of oil missing)
I do understand why
My Very Best
Eric
I do understand why
My Very Best
Eric
All at the expense of us smuck consumers
Wow, I put down 239.9 and you did 241. Pretty damn close if you ask me. I did dyno for about 3500 miles and 1 track day, my car also drinks 0 oil. Maybe Shiv is not that dumb
I do understand why
My Very Best
Eric
I do understand why
My Very Best
Eric
Dynoject 93oct.
BONE STOCK!!!
The Porsches and Vettes get run in at the factory.
Today's engines are built with much tighter tolerances and much improved machining compared to the engines of 10 and 20 years ago. The old concept of "engine break-in" involved two primary elements:
Removing any metal flashing (called swarf) or abrasive material
Allowing valves and rings to "seat" properly. Today's engines do not require these break-in periods. In fact, Mobil 1 has shown excellent control of oil consumption in the industry standard ASTM
Sequence III E test, which uses a completely rebuilt engine for each new test run. This includes freshly honed cylinders, new pistons, and new rings (compression and oil control). The engine is exposed to only the test oil after rebuild. The outstanding oil consumption control of Mobil 1 in this test demonstrates that the old "seating" issue is not of concern in well machined engines. And don't forget that Mobil 1 is used as initial fill on Corvette and Porsche engines.
However, if the engine rebuilder is using older machining equipment or lower quality components, it can leave you with an engine containing swarf or abrasive material inside the engine. In this situation, you would be best served by using a short drain interval on your initial oil fill. Mobil 1 will still work in this situation, but it would be less expensive to use a conventional oil for this first, short duration fill.
If you have any additional questions, you may contact us at our E-mail address: lubes@ffx.mobil.com or by phone at 1-800-ASKMOBIL."
"Thank you for contacting Mobil.
I still had gas in my oil no question about that.
GUESS what guys??? We are seeing as much as 20 to 25 whp differences between stock cars. Witch means the Tolerances are off. Also many people have posted (Darkhorse) block tolerances and tyranny tolerances (Shepard) found during brake down.
It's just cheap insures to run dyno oil for the first few thousand miles.
Come on people is it so hard to believe that
build process has flaws.What make Vishnu such a awsome Tuning house is that they figure out the flaws first then then address them to better tune the cars.
Example
Miata HP ratings were off
Stock STI's knocking and why
EVO boost control, EVO brake in with conventional oil.
My Very Best
Eric
Example
My Very Best
Eric
Example
My Very Best
Eric
EVOs not putting out what expected- increased DL losses and higher octane gas having major effects on power outputs/ Proper recal of factory knock sensor for higher output, nosier cars.
