Snow Performance questions and answers...
Old Apr 11, 2007 | 09:33 AM
  #406
IslandEvoIX's Avatar
thanks man
Old Apr 11, 2007 | 05:02 PM
  #407
Ultimate CC's Avatar
no prob...
Old Apr 13, 2007 | 09:08 AM
  #408
tweakdsm's Avatar
bump
Old Apr 13, 2007 | 09:27 AM
  #409
tweakdsm's Avatar
bump
Old Apr 13, 2007 | 12:55 PM
  #410
C6C6CH3vo's Avatar
Originally Posted by tweakdsm
bump
Bumpwhat?
Old Apr 13, 2007 | 03:05 PM
  #411
SlowCar's Avatar
bump bump
Old Apr 13, 2007 | 03:49 PM
  #412
bump bump bump hahaha...woot woot picked up the vette today
Old Apr 13, 2007 | 03:50 PM
  #413
SlowCar's Avatar
pics!!!!!
Old Apr 15, 2007 | 10:57 AM
  #414
will do once this noreaster goes away...figures as soon as I get the car...
Old Apr 16, 2007 | 07:52 AM
  #415
tweakdsm's Avatar
Finally got my meth to work, everything works! LED's, SI. no leaks. I had to replace Green LED with 12v one, because it kept burning out.
before the tune: we coulnt set the boost, We found leak after boost leak test. Still goes up to 25psi and drops to 22 and MBC would be set all the way in!. weird. So,
We did tune the car, I said lets see what this car can do from 2nd gear. JUST amazing! i ALMOST **** in my pants. BUT after running EvoScan the car picked up 16 counts of knocks!. I pull the power cable out from meth, and we put 93pump gas map back. Still the car is picking up, 6 counts of knocks but the timing is not changing so I should be safe. I hear some ticking noise at idle and will check things today. Knock could be from engine vibration? ...
I really dont want to get rid of the meth, after spending so much time installing it and trouble shooting.
p/s: when tuned on meth we had 23 timing, 11.5 afr and 24psi of boost on my 20g turbo. (And yes my friend knows how to tune the car) yesterday he tunned evo8 on meth and it runs perfect. no knock.
Old Apr 16, 2007 | 07:53 AM
  #416
post up a log, how is the knock, does it come on slowly and then go away slowly or is it sudden?
Old Apr 16, 2007 | 07:57 AM
  #417
hawaiian_evo's Avatar
is there any deals for this kit? (pm me if there is)with the failsafe? looking into sheares 60-1 kit if my 50 bb dont go through
Old Apr 16, 2007 | 08:00 AM
  #418
pmed
Old Apr 16, 2007 | 09:07 AM
  #419
tweakdsm's Avatar
All right I will post some logs tonight when i get home, I will stop by friends shop before that and do some more boost leak tests and check where is that lifter tick (sound) coming from.
knock was with meth around 4000 and 6000 in that range. Even on pump is similar.
Old Apr 16, 2007 | 01:29 PM
  #420
C6C6CH3vo's Avatar
Try running your 93 timing map (or 6 peak, 18 redline) and tuning the A:F to about 11.9:1 - 12.2:1 with 60% methanol. Keep boost to 26 psi and see if the knock goes away. Might even feel and sound better too. Just a suggestion
