Snow Performance questions and answers...
Old Mar 7, 2007 | 12:18 PM
  #346
EVIL MR's Avatar
that's nuts mine is fine in all gears at 28-29 psi but when I hit 5th in lower or higher rpm my forge rs start to flutter really fast. the car want to boost 28 but it keep going to 20.
Old Mar 7, 2007 | 12:20 PM
  #347
Ultimate CC's Avatar
hmm, i use the jdm mr bov, maybe that has something to do with it, when you run through the gears to 5th does it still have the issue or is it just when you take off in 5th from a roll...
Old Mar 7, 2007 | 12:21 PM
  #348
EVIL MR's Avatar
both.
Old Mar 7, 2007 | 12:24 PM
  #349
EVIL MR's Avatar
I called forge and they said that he had never heard of an evo9 running that much boost on the stock gate. I even turned the adjustment all the way which is good for more the 38 psi
Old Mar 7, 2007 | 12:27 PM
  #350
yea that is wierd, stock wastegate can definitely hit 28psi...on nitrous i can get over 30psi fairly easy...
Old Mar 7, 2007 | 12:34 PM
  #351
EVIL MR's Avatar
well I think I will but back my stock bov and see if that do it.
Old Mar 7, 2007 | 12:38 PM
  #352
EVIL MR's Avatar
right after I got tuned I did a top speed run and the car just stalled at about 140 cause the fluttering. I just did not hear it the 1st time
Old Mar 8, 2007 | 01:18 PM
  #353
Does anyone have dyno graphs, if so please post them up...
Old Mar 8, 2007 | 02:01 PM
  #354
EVIL MR's Avatar
Well I found out the the duty on my AVC-R was lower then it should be. Now it's holding 29 psi until 5800 rpm and after that it fall to 25.
Old Mar 8, 2007 | 02:10 PM
  #355
awesome...its always something silly with stuff like that...
Old Mar 14, 2007 | 05:41 AM
  #356
EVIL MR's Avatar
I need to know how much boost are you guys holding at 7000 rpm in 3rd gear?
Old Mar 18, 2007 | 01:16 PM
  #357
4WS Tuning's Avatar
how do i test the pump? i dont remember what 2 wires i need to cross to activate it.
i think my pump is broken, its not injecting.
safeinjection works!
Old Mar 18, 2007 | 01:43 PM
  #358
Evoryder's Avatar
should be the power from the relay that leads to the pump, connect a wire to it and add 12v to see if she spits or just disconnect the top connector of the boost pressure source and connect that to a 12v to see she shudders
Old Mar 18, 2007 | 02:42 PM
  #359
4WS Tuning's Avatar
got the pump to work by connecting it directly.... but the rest of it isn't...
god damnit....
Old Mar 18, 2007 | 04:14 PM
  #360
The Devils Z's Avatar
god damnit....
take the red wire ( power wire ) and connect it to a hot wire. Make sure that the black wire is grounded. Pretty simple actually. DO NOT RUN THIS LONGER THAN A SECOND OR TWO WITHOUT FLUID IN THE SYSTEM. Just long enought to hear it "prime" or pump for a 1/2 second. Should be instantaneous when the red wire receives power.
