Quote:
Will it be possible to demostrate your progressive system spray test in open air? Originally Posted by The Devils Z
if you have the variable controller, it will determine your flow rate for you progressively after you set your onset and max boost.
yes we all know you have your video that you post over and over and over, but you seem to forget that cars have been using much more primitive kits than we have now for years and years and years with great success, the new aquamist pump is great but in day to day use its not very noticeable I assure you, if our pumps didn't work well then don't you think there would be tons of post of people complaining??? Tuners themselves highly recommend the snow kits and its for a reason...not trying to get into an arguement but you need to relax with your ever desire for videos, I just got my car running sunday as soon as I get some free time and things smoothed out I will start posting logs and videos and such for everyones enjoyment...
I have the safe injection with my kit and the 3 leds to show power and flow.. What would you ramp with stock turbo at 25psi? how about a sc61 at 22 ish? any diff ramp setting cuz of the different lag on turbos?
what size nozzle are you running and have you adjusted the pump at all?
Quote:
maybe my standards is just too high......Originally Posted by Ultimate CC
whenever the car is running i will get that...but afrs vary in every gear even off meth...
nothing wrong with standards...u drive an evo don't you?
...i miss something w/ u 2?
Not to scare anyone on here, but this is what happened to my motor when the methanol line came of the pump
# 4 cylinder
look at the scaring on the rest of the pistons
p.s the cylinder with the broken piston still had 170psi compression
# 4 cylinder
The kit that I was using came out of my old duallie Power stroke truck has the variable controller for start and ending psi
NO FAILSAFE
625cc nozzle with pump pressure turned up
I will be having a chat with ultimate cc for some advice on a failsafe system
I am not mad or anything just showing people the other side of meth if not used properly
NO FAILSAFE
Quote:
NO FAILSAFE
Yeah if you're tuned aggressively for meth without a failsafe, this is what happens when your pump fails or nozzle detaches from pump...tough break, live and learn.Originally Posted by antilag_200
The kit that I was using came out of my old duallie Power stroke truck has the variable controller for start and ending psiNO FAILSAFE
Any pix of that kit you had? How'd it come loose? Old tubing...old pump?
I think I have some pictures of it the "kit" I shall post some of them up soon basically the tubing (red) was at a slight angle so it must have just "wiggled " loose I have since replaced that line with AN line to the nozzle
Yes definitely live and learn
Ill take care of you on your next kit or whatever parts you need...
