Snow Performance questions and answers...
Originally Posted by Jussb1aze
anybody have pics of how they installed the pump underneath the windshield fluid resvoir? email them to cwell97@yahoo.com. Thanks.
basic question
How is fluid flow controlled with the proportional kits? Is there an injector that's duty cycled? Assuming there is an injector, how fast does it respond to changes in input values (MAF/boost)? Also wondering if there is any sort of accel enrichment compensation like there is for fuelling.
I hope I answered at least one of your questions, I spent at least 4 minutes.
Good luck!
Yea man, 50 shot of nitrous, its trapped 121.99 with it breaking up the whole way down the track from fouled plugs, it will trap 124 I guarantee when I get the map smooth... http://www.youtube.com/watch?v=1f8WoWFYHvM is the video from that pass...
Originally Posted by C6C6CH3vo
Pump voltage from kit controller
Not sure but there is a nozzle and the pump is the only thing that has duty
The voltage increase in respect to MAF/Boost ramp is instant...
Good luck!
Good luck!
Interesting. I'm a bit surprised it works on pump speed. I wouldn't have thought that a pump could keep up.
the only system that is able to react instantenously is the pressurised Aquamist system. Injectant, at high pressure- is held behind a HSV(high speed valve), capable of pulsing at 250Hz. With the appropriate injection nozzle size and pulsing in sync to the fuel injectors, injectant to gasoline ratio can almost be kept to a 1 to 1 ratio
