Snow Performance questions and answers...
Old Jul 19, 2006 | 09:26 PM
  #121
Ultimate CC's Avatar
nice vids...
Old Jul 19, 2006 | 09:53 PM
  #122
EvO6-RS2's Avatar
^^^^Good Stuff...
Old Jul 20, 2006 | 08:23 AM
  #123
C6C6CH3vo's Avatar
Once I save up for a clutch I will post some runs in 4th gear to better show the mode
Old Jul 20, 2006 | 08:50 AM
  #124
~EVILEVO~'s Avatar
I was looking at the control box and there are two adjustable dials, my question is there is a start spray and a full spray correct? well if your start spray is say 5psi and your full spray is say 10psi but the does it continue to spray if I run like 40psi of boost?
Old Jul 20, 2006 | 09:07 AM
  #125
C6C6CH3vo's Avatar
By setting the start and full dials of the controller your just setting the ramp from no spray to full spray. So if you set the start at say 5 psi and full at 6psi then at 6psi the pump will be operating at max output all the way to 20, 30, 40, 60 psi - whatever, until you let off the throttle.
Old Jul 20, 2006 | 09:23 AM
  #126
~EVILEVO~'s Avatar
cool that was my only concern about this kit. thank you for you help
Old Jul 20, 2006 | 04:32 PM
  #127
~EVILEVO~'s Avatar
Ok got a few more questions. Is there ever a time for the "kit" to be turend off, say for race gas. Just wire a toggle switch in? also I dont know if anyone has tried this before but could I run two nozzels? not at the same time but one very close to the throttle body for 91 oct. and one however futher down for race gas? some how switch thte hose to whichever nozzle I want to use?
Old Jul 20, 2006 | 11:38 PM
  #128
You can hook up a toggle switch, this is what I have in my car, I will try and post some pics of that, and as for the two nozzle setup, there really isn't a need to do that...
Old Aug 2, 2006 | 05:11 PM
  #129
EvO6-RS2's Avatar
HELP from you guys who installed the snow kit!!
The nozzle holder assembly comprises of the following in order of assembly from nozzle up to hose...
1. Nozzle
2. Nozzle Holder
3. Cone Shaped piece
4. Washer
5. Nut
6. Nylon Hose
My question is:
What direction does the flat side of the washer face? the nut or the cone shaped piece?
Old Aug 2, 2006 | 06:55 PM
  #130
EvO6-RS2's Avatar
Got this response from DAN @ Snowperformance...just so you guys know:
Flat side of washer faces the nut, your assemble order below is correct.
Narrow side of cone points into holder not at nut. Make sure screen side of
nozzle points inside holder.
Yes make sure it is really really really tightened down good at the nut and
will hold for many years to come.
Old Aug 7, 2006 | 12:57 PM
  #131
Levar's Avatar
Veteran: Army
I have the Engine Runup alky/meth kit, however, I am using the Snow Performance safe injection with it. I've read through the 150 or so posts and I have a question or two about the the mention of epoxy and "GOOB" (whatever that stands for). I see that I can go to www.mcmaster.com to get "whatever" I need. I've piece-milled this kit but if there's something additional that I need in order to have a safe installation, then I'm hoping to get onboard. So, what exactly am I to purchase from McMaster? Also, I still haven't read whether or not an ARP head stud is necessary. I'm thinking that for $100 or so dollars, that it can't hurt to have them just in case something goes wrong. What does VC25 mean? Thanks in advance for answering these concerns of mine.
Originally Posted by SlowCar
MOAHS = mother of all hardware store = www.mcmaster.com! lol... they got everything!
Old Aug 7, 2006 | 01:01 PM
  #132
Levar's Avatar
Veteran: Army
I'm also looking for a reputable person to install my kit. I'm in the Central Texas area around Austin.
Old Aug 9, 2006 | 09:56 AM
  #133
sgevotx's Avatar
Try call precision-r at san antonio, they install my SP kit and failsafe.
Contact Information
Phone: (210) 829-8200
Fax: (210) 829-8250
Address & Driving Directions
2405 Boardwalk
San Antonio, TX 78217
Old Aug 9, 2006 | 07:34 PM
  #134
Levar's Avatar
Veteran: Army
Contact Information
Fax: (210) 829-8250
2405 Boardwalk
Thanks bro. I'm sending them an email right this minute.
Old Aug 26, 2006 | 02:35 PM
  #135
EvoG8r's Avatar
I called Sunshine in Killeen and they have experience installing alky kits on domestics... they said it would cost between $180 - 350 depending on complexity... or $60 per hour.
