Snow Performance questions and answers...
Old Dec 1, 2006 | 04:37 PM
  #196
4WS Tuning's Avatar
can't find what size drill bit i need to tap into the uicp pipe
what did you guys use?
thanks!
Old Dec 3, 2006 | 09:27 AM
  #197
TurboTodd's Avatar
nozzel install
I would not drill and tap the thin wall aluminum pipe as this could leak and fail very easy. Mark the spot where you want your nozzel. I prefer about 3" away from the blow off valve closer to the TB. on the bottom of the pipe. Stealth is always a cleaner install. Take the pipe to a local fab shop and they can weld a bung with 1/8 pipe already tapped for you. the nozzel should be flush with the interior wall of the pipe for the cleanest fit. If you bring the nozzel with you they can get the depth right. Good luck!
Todd
Old Dec 3, 2006 | 07:08 PM
  #198
EVIL MR's Avatar
Ok how and where did you all placed the bump? Is it standing up or what. I can not place it under the tank. Any pics will be great.
Old Dec 3, 2006 | 07:14 PM
  #199
Ultimate CC's Avatar
I used to have pics of my setup in the trunk, if you give me an email I can send you how I now have the pump mounted...
Old Dec 4, 2006 | 01:55 PM
  #200
EVIL MR's Avatar
You got mail!!
Old Dec 4, 2006 | 01:57 PM
  #201
mail returned...
Old Dec 4, 2006 | 02:26 PM
  #202
Evoryder's Avatar
i love meth....any dual stage setups out here?
Old Dec 4, 2006 | 03:08 PM
  #203
I know a couple are lurking but most go with single...
Old Dec 4, 2006 | 03:12 PM
  #204
4WS Tuning's Avatar
i spoke to greg at snow performance and got everything straight... if ya wanna know what we couldn't figure out PM me!
thanks for the help!
cheers!
Old Dec 4, 2006 | 03:13 PM
  #205
glad that all worked out for you...pming you now...
Old Dec 4, 2006 | 03:22 PM
  #206
Evoryder's Avatar
i got mine setup dual...just wondering how others have done theres...
Old Dec 4, 2006 | 03:24 PM
  #207
post some pics up if you have any...
Old Dec 4, 2006 | 03:28 PM
  #208
Evoryder's Avatar
no pix...it's hidden...utilized the 03 pump...i don't get on the dual setup long...stock pump is strong...just not designed for prolonged use...i'll take some pix when i install my low fluid light this weds
Old Dec 4, 2006 | 04:28 PM
  #209
sounds good...
Old Dec 7, 2006 | 08:53 AM
  #210
Evoryder's Avatar
