Snow Performance questions and answers...
I still did not complete the install. but I wanted to know is the green light stay on since the time you start the car or only when the spray is on? after I talked to a snow tech "Our systems do not need to be fused because the controllers have internal circuit breakers. This does however create the same condition you’re mentioning (loss of power to controller and pump). Unfortunately that is one down side to our SafeInjection. You can wire the SafeInjection to a dedicated 12 volt source however it will always be detecting a loss in flow when ever the system isn’t injecting and it would limit your boost by means of the wastegate solenoid" I will be using my AVC-R to control when I will go on high boost and for how long the rest of time it will not go over 23 just in case of...
Anyone running the 2D kit? I've installed the stage 2 maf kit on a couple of local turbo 5.0's and SC'd cobras with great success. I just have no experience with the 2D kit and if it offers any real world benefit over the regular MAF based kit. Any input is greatly appreciated. Thanks
jeff
jeff
jeff
jeff
im using the 375cc nozzle ... i have my pump turned up a little higher than it came as you know.. after my first couple logs it didnt seem rich enough for the addition of meth so i turned up the pump and it got rich... i turned it up again.. and it got rich... to the point where it wasn't getting any richer. its not up all the way, but its nearly there.
did i do something wrong or is that normal?
and ive noticed it really use's a lot of the meth.. i did about 6 WOT logs and the tank dropped about an inch. is that normal?
