Another alky injection project
Old Jan 21, 2007 | 03:35 AM
  #76
SlowCar's Avatar
Aquamist DDS3 failsafe in action
Click here to watch dds3
Car shooting fire. This one was at the end of the afr tune......initial ones were BIG:P
Click here to watch fire-91-80
Old Jan 21, 2007 | 03:59 AM
  #77
SlowCar's Avatar
The car is so fun to drive, feels like its shed halfs its weight!
Old Jan 21, 2007 | 05:33 AM
  #78
EVO8LTW's Avatar
Wow...huge gains! Congrats!
Old Jan 21, 2007 | 07:25 AM
  #79
Richard L's Avatar
abner, you deserved what's coming to you, in the nicest way!!! Well done. I have problem downloading the video, will you be able to email the DDS3 clip to me via email attachment?
How much methanol did you used up on the session?
Old Jan 21, 2007 | 09:22 AM
  #80
SlowCar's Avatar
Richard, you got mail.
At peak torque, volumetric ratio of 93 octane gas to methanol is ~ 1:1
used up 0.45 gallon methanol for tune
Old Jan 21, 2007 | 09:26 AM
  #81
Ultimate CC's Avatar
nice...fire is great isn't, it always shocks the people behind you when a 6-12 flame comes out after letting off the gas...
Old Jan 21, 2007 | 09:27 AM
  #82
SlowCar's Avatar
when the tune was done...there was no more fire
Old Jan 21, 2007 | 09:29 AM
  #83
EvoTio's Avatar
Wow, good job! Doesn't it feels good to see some nice results after you put a lot of hard work in a project? Now take it to the dragstrip and have some fun!! Joe.
Old Jan 21, 2007 | 03:51 PM
  #84
SlowCar's Avatar
thanks Joe!
Old Jan 22, 2007 | 02:56 AM
  #85
Richard L's Avatar
Abner,
I have reloaded the video files to the following site:
(only work with microsoft Internet Explore)
DD3 in action
Breathing fire
Old Jan 22, 2007 | 03:27 AM
  #86
SlowCar's Avatar
Thanks Richard!
Old Jan 22, 2007 | 09:41 AM
  #87
Richard L's Avatar
Abner, you were wise not to go for a pump speed controlled system. Here is a recent log with a DDS3 sensor on a "progressive pump speed system" It refleced the video posted earlier:
http://s8.photobucket.com/albums/a32...3092006011.flv
1- 4th gear pre-turbo ramp
2- Passed the wastergate
3- Throttle shut (avoid hitting the car in front) meth continues to flow
4- Threttle re-applied (controller never pick this event up)
5- End of run, meth continues to flow.
Old Jan 22, 2007 | 12:50 PM
  #88
SlowCar's Avatar
from the data shown, a good analogy for progressive pump speed systems would be like taking a swing at a fly with a sledgehammer(pump rotor) is too massive to react to transient change thus injecting too little when needed and too much when not needed
Old Jan 22, 2007 | 08:29 PM
  #89
EVO8LTW's Avatar
How does the system cut boost on a fault event? I've looked at the DD3v8 manual and I see the pin outs, but it looks like you need additional parts -- like a solenoid of some sort to send pressure to the wastegate.
Thanks,
Rich
Old Jan 22, 2007 | 08:54 PM
  #90
SlowCar's Avatar
yep, a solenoid valve to send pressure to open up the WG. 2 very good valves:
either the aquamist part # 806-234 or the mac series 36 valves
