Nitromethane Q&A..
Old Aug 15, 2007 | 07:18 PM
  #91
SlowCar's Avatar
Originally Posted by dudical26
Bad news - It seems the nitro tune made less power.
Meth is benchmark
you log your AFR? Possible too much timing for leaner/faster burn?
Old Aug 15, 2007 | 08:08 PM
  #92
bnice01's Avatar
I had to take a quite of bit of timing, because of the nitro no log of the AFR's
the logs are 4 days apart not back to back but at the same time of night I confused it feels faster and pulls harder to redline. to be honest with you it wasnt on the same road, the log for the nitro was done on this ****ty road that was uneven. here is a new log, the only thing I changes was added the colder plugs. to let you konw how senstive this stuff is I tried to add 1 degree of timing in the mid range boom 1-4 counts of knock retard 1 degree back boom 0. so lets hope for improvement. alright dudical lets see it made an improvement over the meth, thanks again man
File Type: zip
Old Aug 15, 2007 | 08:34 PM
  #93
bnice01's Avatar
this is what I got after the new log, however with the old nitro log i did see a power loss as well, probably due to the uneven surface of the pull
meth is the benchmark
Old Aug 16, 2007 | 06:53 AM
  #94
bnice01's Avatar
i will add this i know the car is over 400 (dll numbers) because dll wont let me adjust the tire size. example it said I had 389 with the 235's so i installed o2, fmic, added 8-10 degrees more timing, and the 255's. The new #'s were 370. more mods, better tune, wider tires "power loss" LOL.
Old Aug 16, 2007 | 12:55 PM
  #95
dudical26's Avatar
Here is a new graph using your new logs, again the benchmark is meth
In order to be accurate it really needs to be on the same EXACT road.
Old Aug 16, 2007 | 04:20 PM
  #96
bnice01's Avatar
i know i know, you told me that before . but that log was the same road made sure of that again thanks bro for posting it up.
Old Aug 16, 2007 | 04:53 PM
  #97
dudical26's Avatar
so far this looks promising.
IF you get a chance to do back to back logs of just meth and the nitro again, I think that would give us definitive answers.
Old Aug 17, 2007 | 11:57 AM
  #98
bnice01's Avatar
x2 i agree, i will try to do that this weekend dont know yet i have to help a friend pull is blown motor out of his srt
Old Aug 17, 2007 | 10:04 PM
  #99
Ultimate CC's Avatar
im interested to see what others make with this nitro, i had nothing but power gains from it but never got to dyno it or anything like that but wish i could have...
Old Aug 17, 2007 | 10:54 PM
  #100
bnice01's Avatar
man this **** is crazy, i just put these plugs in and there misfiring already. there gapped around .023 i am going to try to run them lower. nitro seems to be eating these plugs but she pulls hard as **** with a big *** orange flame with every shift LOL
Old Aug 18, 2007 | 02:36 AM
  #101
Richard L's Avatar
I am a bit confused with the caption below/above the dyno chart, are you loosing or gaining power?
I look forward reading the next chart.
Old Aug 18, 2007 | 04:02 AM
  #102
SlowCar's Avatar
Old Aug 18, 2007 | 04:09 AM
  #103
94AWDcoupe's Avatar
If you dont make more power using nitro you are doing something wrong. A friend just dynoed his pickup truck for kicks. After he got a baseline he dumped a few ounces of rc car fuel in the tank. the amount of nitro in the overall mix was minuscule. picked up 12whp on next pull.
Old Aug 18, 2007 | 06:26 AM
  #104
bnice01's Avatar
94awdcoupe read post 92 and down. I was on an unever road thats why the numbers were lower. I did another pull post 95 were the results
Old Aug 18, 2007 | 10:08 AM
  #105
Evoryder's Avatar
you really should log on the same road for consistent comparison results
