100% Water, anyone making power?
....Sorry about that, its just a little bit irritating that there is such a lack of knowledge in this industry.
Needless to say, I have been there, and while it does not take anymore "skill" it takes the understanding of what your attempting to do.
A Stoichiometric A/F ratio for a given fuel or a Lambda Value of 1.0 should produce the highest Theoretical flame temperature. In lay mans terms, at that ratio of Air to Fuel, the combustion temperature should be the hottest. So when people say running lean is hot, its a matter of perspective. If you are leaner or richer than the Stoichiometric A/F ratio for a fuel, your combustion temperatures will be lower that the maximum. This brings about the question of... If thats the case why don't we run leaner than stoich? The answer is basically two things. The first is thermal management, and the second is a power production window. But we wont really head into that discussion. But for the time being, let it be said that an engine will make the same amount of power with a wide range of A/F ratios as long as the combustion is regular, meaning no detonation, knock, preignition, what have you.
We typically run turbo engines richer than stoich, and with evo's in particular on pump gas, 91-94 octane, somewhere in the region of 11.0:1 to 12.0:1 determined by many factors. If we begin to take fuel away, combustion temperature begin to rise due to less mass of fuel removing heat. The result typically is the onset of irregular combustion (detonation, etc.). If we inject water, we can quench this irregular combustion. To little, and irregular combustion continues due to excessive temperatures, to much and you effectively "bog" the engine. The key is to replace the fuel taken away with an appropriate amount of H2O that will quench detonation. As you AFRs approach Stoich, not only are you running a more efficient AFR, but you are also injecting a volume of water that takes up space and effectively raises your dynamic compression ratio. You can now run much closer or at MBT.
Here's the kicker, lets say your at peak torque and you have a 100% Water Injection setup running 14.2:1 AFR and you run out of water. BOOM... or a little bit slower than that. All of your cooling is gone, your engine is detonating and the combustion temps are pretty much as high as they can get
. Blown engine time! Good luck Guys!
the thing you want to keep in mind with anything you inject, is its likelihood of clogging the injector. That could come from sediments or scale, tap water from the Southwest comes to mind. Even here in the Northwest I use distilled water to keep mineralized water to a minimum.
So look at the contents, will it leave a residue that will dry and clog?
If you are willing to dismantle and clean your injector often then your problem is less.
Import Junky
69
Sep 21, 2010 04:38 PM
8-BallEvo
62
Jun 13, 2010 02:29 PM
scheides
15
Jul 25, 2008 06:39 AM
