Las Vegas Evo's
Sunoco makes great fuels....The pump 100 we have here is probably 96 motor octane, Jeff. Not ideal, but still way better than the 91 **** we have at the pump. It is actually fairly widely available too. I have 3 stations within 2 miles of me that carry it. Have you considered e85, like Alan suggested?
man,how do you suppose that happened. i just got a IX turbo not too long ago aswell. i havent got to run it hard as i am breaking in the new clutch . good luck and keep us updated. . .
the nut was all loose on the intake side and shaft play up and down as well as in and out. the blades look like they've nicked the walls and that's probably what the whine sound was that I heard. I just limped it home the other night staying low rpms no boost. I'll probably take the turbo off tomorrow or sometime this weekend.**** it'd be nice if someone wanted to sponsor me a turbo
....damn wesside needs a sponsor haha
are you runing meth on top of it? I considered doing that
yeah thats where I filled up too, it only does it when I'm on 100% throttle and higher loads in 2nd, 3rd, 4th, 5th gear.
I turned my boost as low as it will go and still misfire, so my only option is to gap down the plugs see if that will fix it.
go back a few hundred pages and see what I posted about e-85 with cold weather haha Your not going to have any problems running it with the warmer temps and Dan if you wanna meth kit lets get the aquamist installed on the ix with ecu boost control and the tephra alt-map switching patch to use as your failsafe and be able to swap tunes & boost levels on the fly
I hear ya, at the power level you are at, I would run a fuel that is more consistent, 100 octane here has always been good and they carry it at a lot of gas stations here.
I was only running 28lbs
I bought the denso ikh24's which are iridium and I left the gap what it came as, I believe the are .028 and from what I have been seeing e85 tunes people gap at .020 I would rather not mess with an iridium plug but I have nothing to loose at this point, so I will try gapping them down see if that will help
Having the colder weather isn't the problem. During the majority of the year from I think it is March-October, the pumps will be dispensing e85 and you won't have any issues. It is the crap winter blends that we all seem to be having trouble with.
On another note, I did a little experiment tonight. Gassed up a quarter tank at Huey's on Vegas Drive and Decatur. Drove the car on the 95 in a very spirited fashion. No issues with misfire. Gassed up not 2 hours later after running around for 10+ miles with the low fuel light on at Vegas Valley and Nellis. Did a 2nd/3rd pull and the car was misfiring and knocking like a ****. I think Rebel is filling the pumps with e70.
Feel alot better now that I'm not alone with the whole misfire issues! Thanks Doug and Alan for your help tuning the car. The car doesn't stall anymore! It really cool kickin with you guys!
