Utah Evos
Old Mar 16, 2009 | 08:30 AM
  #21436
wesside's Avatar
Speaking of map sensors does anyone have a 3bar there getting rid of??
I'm gonna take off here in a few and I'll be back in a few weeks....Dallin you better wake up foo when I'm come thru so you can get this mbc
Old Mar 16, 2009 | 09:55 AM
  #21437
DIDYSIS's Avatar
How do you like your air/water?? you buy it on here or somewhere else?
Originally Posted by Fairclough
28psi low boost, 36psi high boost, remember i have air/water intercooler and meth.
Old Mar 16, 2009 | 10:10 AM
  #21438
Jorda420's Avatar
^ he custom made it yo
Old Mar 16, 2009 | 10:14 AM
  #21439
DIDYSIS's Avatar
ya that's what i was thinking of doing myself. I like to make everything myself as much as possible.
Old Mar 16, 2009 | 10:21 AM
  #21440
DIDYSIS's Avatar
So your in West Jordan? I think I have seen you around 7000
Old Mar 16, 2009 | 11:42 AM
  #21441
Jorda420's Avatar
yep thats probley me I got a lancer wing on the back
Old Mar 16, 2009 | 11:47 AM
  #21442
Evolution IVGSR's Avatar
I spotted a Red Evo yesterday up in SLC at around 500 S. and 400 W. Looked Clean man I was with the Gray Evo X with Black wheels.
Old Mar 16, 2009 | 11:52 AM
  #21443
DIDYSIS's Avatar
When when you all see a RR MR running around that is load and has a custom made badge on it thats me :-) should be getting the tune setup to go drive a little bit, just need to register my car here finally. inspection might suck well let me say that again, sucks have to do them, but I understand, wont be doing emitions because of change of address. Anyone have best place to go around West Jordan??
Old Mar 16, 2009 | 11:54 AM
  #21444
DIDYSIS's Avatar
I have seen a few Evo x's around here. More than Washington.
Old Mar 16, 2009 | 11:55 AM
  #21445
gear head's Avatar
When when you all see a RR MR running around that is load and has a custom made badge on it thats me :-) should be getting the tune setup to go drive a little bit, just need to register my car here finally. inspection might suck. Anyone have best place to go around West Jordan??
made any progress with you're lean idle?
Emission testing guys, do not read this next sentence
There is a monitor patch so we can set them to PASSED
Old Mar 16, 2009 | 11:58 AM
  #21446
Jorda420's Avatar
I might be able to help you out. Im at Just emissions on 90th and 1835 w
Old Mar 16, 2009 | 12:06 PM
  #21447
DIDYSIS's Avatar
Ya its running rich now. So things are looking good, had an exhaust leak and that was it. I just want to set the car up to baby it around for now. Break in the motor and then work on it more, Well really it will prob be a full work in progress all the time. Still I am sure I am going to get into things that I dont know fast. trying not to get the Tephra 5.10 mod done to my setup. sure would be nice. I am thinking if I want to try to setup a blow thru now or a speed density. So much stuff. Wish i was close to a shop owner/group that could help me setup a ton of crap and double check everything.
Old Mar 16, 2009 | 12:08 PM
  #21448
DIDYSIS's Avatar
Do you guys to the inspections also?? I am going to register my car at Dads house in Aurora so wont need emitions, just an inspection. I have a cat its just empty
Old Mar 16, 2009 | 12:21 PM
  #21449
Jorda420's Avatar
Come on down we do it all plus you get the hookup
Old Mar 16, 2009 | 12:24 PM
  #21450
gear head's Avatar
For sure, it will always be a work in progress, maybe even an addiction
The progress the brainiacs are making with the ecu is happening pretty fast these days, if you end up needing any help with the patches I can do most of it through email...aside from plugging pins into the ecu. My ecu has almost every patch known in it & will be switching to Tephra V6 as well as speed density when released
