Utah Evos
Old Apr 18, 2009 | 04:26 AM
  #23011
~BoOsTeR~'s Avatar
Originally Posted by wesside
I just might do that what hrs you gonna be there??
8 - 6 man
Old Apr 18, 2009 | 05:33 AM
  #23012
Fairclough's Avatar
You should take a picture so I and other can see wtf your talking about
BTW Welcome new evo owner and to the threads
Looks like you've got the body kit that Jason (farclough) has
It's a different kit! looks good though. I'll be at the shop all day today, stop by if you get a chance.
Old Apr 18, 2009 | 07:09 AM
  #23013
gear head's Avatar
So, does anyone out there have an Idle Control Stepper Motor they would part with?
It would be so cool if the car would idle again
Old Apr 18, 2009 | 08:10 AM
  #23014
sikwititevo9's Avatar
Originally Posted by TwoFour
I have some grounding issues I believe.
Where did you ground and mount your amp? What gauge wire are you running? Through the firewall? Where did you ground your head unit?
I might have more questions soon!
i grounded my amp to the the floor of my trunk. i am using a 4 gauge wiring kit. i ran the power wire through the firewall on the passenger side if you take out your gllove box there is a rubber gromet you can either make a hole through it or take it out, but its way back there kinda hard to get to so someone with lil hands comes in handy. if you are looking at your firewall from under the hood the whole is behind the strut tower but kinda a tight squeeze. and you head unit you can ground straight to the screws that hold the unit in or one of the screws that are already there just hook it up to one of those all it needs is metal to metal contact. if you need more help let me know.....
Old Apr 18, 2009 | 08:29 AM
  #23015
does anyone remember the address to jasons shop?
Old Apr 18, 2009 | 08:44 AM
  #23016
Sully 18's Avatar
im from new jersey...but i flew to ogden utah cause my gf needed surgery....im at a marriott bored out of my mind....SOMEBODY PICK ME UP LOL
Old Apr 18, 2009 | 08:46 AM
  #23017
Sully 18's Avatar
its 4/18 right now
Old Apr 18, 2009 | 09:05 AM
  #23018
Originally Posted by Sully 18
its 4/18 right now
what hospital are you at?
Old Apr 18, 2009 | 10:14 AM
  #23019
wesside's Avatar
He's at a Marriott
Odgen is the one that's north isn't it?
Old Apr 18, 2009 | 10:16 AM
  #23020
wesside's Avatar
Cool I'll stop by after lunch sometime
FTL what it cost new??
Old Apr 18, 2009 | 10:18 AM
  #23021
jaycheetwood's Avatar
Anyone going cruising tonight? I will hopefully have my EVO today and im down to take it out.
pm me or something ill be on and off here todya
  #23022
Sully 18's Avatar
think so..im used to seeing beaches not mountains ..... 247 24th street is where the marriott is..im going out of my mind sitting in this hotel
Old Apr 18, 2009 | 10:21 AM
  #23023
wesside's Avatar
Originally Posted by 33
Hey now, I take offense to that Jake! Trying to make me feel bad cuz I dont have a car anymore? JK!
Sounds to me like he is talking about the thin piece of metal that bolts onto the bottom portion of the bell-housing right below the block. The one that has like two lil 8mm bolts you take off and can see the flywheel. Does that make sense, or am a talking about a different tranny? If that is the case, it shouldnt take days to put a new one back on. If I remember right, there is nothung to remove to access that other than the under tray.
yea that's probably what it is, the small cover that goes on block under the flywheel..I've got a extra one in Vegas in my friends storage unit But you gotta unbolt and pull the tranny away from the block so you can get the plate on I think if I remember right? A lot of dust and **** is probably gotten or getting inside and at that point it's probably best to have everything taken a look at and cleaned clutch side and inside tranny
it's been awhile since I did a tranny/clutch...last october, you might be able to put the dust shield on by just getting under car but I think it's bolts going in on the flywheel side to the block
Old Apr 18, 2009 | 10:25 AM
  #23024
wesside's Avatar
Hey Wes, its back but with a new url.
http://www.watch-movies-links.net/
****ing sick I was bummed out that link went dead
Old Apr 18, 2009 | 10:35 AM
  #23025
Sully 18's Avatar
if u guys cruise tonight that would be great if some1 picked me up
