Utah Evos
Old Apr 23, 2009 | 04:32 PM
  #23506
mountainturbo's Avatar
Originally Posted by WarmAndSCSI
Almost all widebands have a Nernst-type narrowband output. Some are even programmable. You just wire in the output of the wideband to the signal input for the stock O2 sensor. But you have to keep the front heater circuit in tact. Voila! I did this on my Galant, but it was more complicated being that it had 4 O2 sensors.
Yup, pretty much! The zeitronix I have lets you set the narrowband "switching point", so I have it set so the car thinks it's running 14.7:1 when it's actually at 15.2:1 for better fuel economy.
I don't think I kept the front heater circuit though, I'm pretty sure I disabled it in the ECU, but it's been a loooong time since I did it I just know the front o2 isn't hooked to the ecu anymore...
  #23507
UT_Evo's Avatar
Originally Posted by Jay644
I've had 20% for almost 3 years now between my evo and the rsx. It does appear darker on a black car but my gf and i have never been pulled over or cited for it. I was pulled over for speeding the morning of the last meet we had and the HP just "advised" me that it was too dark.
All the other times I've been pulled over, which isn't many, they never metioned anything. HP was just being a dick!
That's good news then!
Old Apr 23, 2009 | 04:33 PM
  #23508
WarmAndSCSI's Avatar
I knew you could wire it to the ecu for logging and such, but I didn't know you could do this and completely remove the stock primary o2. Will doing this result in a more accurate AFR reading for the ecu to work with?
Yep, it will. And with a programmable output on your wideband, you can have the ECU run leaner under closed loop, which is not possible with a narrowband sensor which only knows how to identify 14.7 AFR. Some people target as lean as 16:1 for fuel economy.
Old Apr 23, 2009 | 04:37 PM
  #23509
Sully 18's Avatar
so hows the weather in good old utah?
Old Apr 23, 2009 | 04:40 PM
  #23510
UT_Evo's Avatar
Slowly moving towards the raininess we're supposed to have over the weekend.
Old Apr 23, 2009 | 04:41 PM
  #23511
Jay644's Avatar
Hey whats up man, haw was your trip back?
Old Apr 23, 2009 | 04:43 PM
  #23512
TwoFour's Avatar
Originally Posted by mountainturbo
If you delete the o2 that you have now you'll have to tune the ECU so you don't throw a code. If you have an o2 bung welded on you can just run both the wideband and the stock o2.
I have my wideband in the stock rear o2 spot and the stock o2 is removed. I also have the wideband fed into the ECU in place of the front o2 sensor so I can cruise around with the car a bit leaner than stock
do you have to re-pin the Ecu?
Old Apr 23, 2009 | 04:45 PM
  #23513
jaycheetwood's Avatar
Originally Posted by wesside
nice that's what I've come to determine..i've got denso 720cc so with Jaremt's car I should be able to use my same voltage latency & scaling to get his injectors dialed in
so I just climbed a telephone pole fireman style and saved a cat
you seriously got that cat it was still there???
Old Apr 23, 2009 | 05:08 PM
  #23514
No you just splice in the narrowband output of the wideband.
Old Apr 23, 2009 | 05:10 PM
  #23515
UT_Evo's Avatar
Wes: Gets all kinds of *****.
Old Apr 23, 2009 | 05:11 PM
  #23516
  #23517
Well i saw that ***** last night and lemme tell you.. it was definitely hairy and ginger
Old Apr 23, 2009 | 05:18 PM
  #23518
DIDYSIS's Avatar
Any more Alignment Tips or best specs for normal spirited driving :-)
Thus far
1.8 Camber in front and 2.0 in the rear, toe corrected all the way.
Old Apr 23, 2009 | 05:22 PM
  #23519
DIDYSIS's Avatar
The Gauge pod forsale what size is it and its a replacement for the top of steering wheel column. Pic please!!
Old Apr 23, 2009 | 05:30 PM
  #23520
Timmay81's Avatar
mine is 2 1/16 gauge and it goes over factory piece
